No HDMI sound or speak/headphones sound
No, not necessary, just wondered what that was, K, now , do you have a red speaker icon down in the task bar , if so, when you right click and then see a window, what do you see when you open Sound Manager ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Yes my speaker shows a red circle with a white x in it. What do you mean by "sound manger"? all I see is open volume mixer , playback devices , recording devices , and sounds.
No, not that, a red icon of Realtek HD Audio Manager , Go to Start> Control Panel > Device Manager> Open up Sound, Game and Video Controllers , You should see the Realtek High Definition Audio . See if you have that please.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Right click it and the ATI HDMI Audio and see if they show working properly.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Go to start button, in the search window you see there, paste this between the arrows < C:\Program Files\Realtek\Audio\HDA\RtHDVCpl.exe > and see if it takes you to the file. If so, right click it and select Run as Admin. See if this gets that rascal opened up .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yeppers, that is your Audio Sound Manager . Now , see if you can get the sound working , test the speakers out . Configure the speakers, test sound out. Post back if you can get this working now.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Hmmm. Highlight Speaker , which has a check mark in it, then click set as default . Put a check mark in appropriate box. Front , left and right or surround sound, then press the test button.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Speaker config, drop down, set at Stereo
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Use 5.1, the fact that it has check mark would , apparently , indicate it is set as default, i just checked mine. Use 5.1 config and see if it test out now
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Do you have another computer to test those speaker out on, you should have sound, just by an overlook , you do have volume turned up, right ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Playing with mine again, try the 2.1 , does it show pic's of speakers on that Window of Sound Manager ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Is this a Laptop with built in speakers ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
