The front panel is connected to the MB and the jumpers are set correctly. Only with the new drivers since the R2.08 i got this problem.
Yes, then you need to go back.
Go to device manager, select your audio device, select the Driver tab and finally select Roll Back Driver.
If this fails to work then you will have to use an application like driver sweeper to remove the old driver and then reinstall the last known working driver.
Guru3D - Driver Sweeper
Pooch
- Self build
- Phenom II x4 Black Edition 940-Arctic-Cooling Freezer Xtreme
- Asus M3A32-MVP Deluxe
- 8 gig Samsung PC800 RAM
- NVidia 9600gt
- AD1988b
- 22" TFT-MONITOR WIDESCREEN mit VGA/DVI 17" Video7 TFT
- 1680 : 1050 1280 : 1024
- Drive #1 - SAMSUNG HD252HJ (250 GB) Drive #2 - Hitachi HDT721010SLA360 (1000 GB) Drive #3 - SAMSUNG HD250HJ (250 GB) Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
- PSU
- Thermaltake Toughpower Cable Management 750W
- Case
- Enermax Chakra
- Cooling
- 2x 120mm Front and Back 1x 250mm Side
- Easy Line Laser Mouse
- Standard
- Other Info
- I have also used Fedora, Suse, Ubuntu Linux And all other Windows from 95 to date except ME
