Lightning Speed
There ya go.. Good man!
3.15 GHz with temps of about 40c idle is pretty decent.. it should be a little less as I get those on 3.6 GHz .but I also have a better cooler than yours. but either way those are good enough.
I'd like you to run something like Prime95 to check stability like you said you would. and give it a good at least 15 mins. and hopefully you don't get any errors. I'm thinkin you'll be ok and it will run fine. but what I want you to do. is run it for about 15 mins. and then look at your temps. I'd stay and watch just in case. I'm pretty sure your cooler will handle the job. but the Max load temps are more important than the idle temps. so even though your fine with temps around 40c.. you'll need to watch the load temps while running Prime95. and as long as they stay under 65c your fine. I'm interested to see how your Cooler handles the stress actually.
So, good job. well done. your welcome. there's something else though.
as far as your question about setting the ram to 850.. personally setting my ram from 800 to 1066.. didn't do ANYTHING. other than raise my score in WEI from 5.7 to 5.9 and that doesn't really matter at all.. do you know what that is. the WEI.
Oh and don't try to put your ram to 1066 either.. it probably wont work. mine's actually 1066 ram. but I run it at 800 because it makes my OC more stable. yours could probably do 850 if you tried.. but theres really no reason to at all. But if you could tell me what ones you have. like a link to the actual ones you have. I could tell you more. as theres tons of corsair memory.. are yours Dominators?
So ya, leave the RAM on 800, and try a Prime95 test to check full load temps. oh and one more thing.
I see in your CPU-Z shots that both of those overclocks are working with 1.400volts.. is that what you set it to in the BIOS. did you set it to 1.4v. that was my suggestion. but I'm actually pretty sure you could use less than that.
Before you try to do to much.. you need to get the voltage figured out a little bit, all are different. so I can't say what actually to do. but basically do this. either do it now, or do it after you get to 3.2 GHz.
If you do it now, do this. leave it at the 3.15 GHz that your at now.. and leave the speed the same. yet go into the BIOS. and change the voltage to lets say 1.35v or something in that area.. then go ahead and boot up the system.. if it boots, then thats good. if it crashes, then that means you need more voltage and maybe go up a little higher. but I'm pretty sure it can boot at 1.35v. so try that. and if it boots and works.. then run Prime95 and see if it goes without error. if you get errors let me know..
Get all that. lets recap. Leave ram to 800, do a max load test to see full load temps. and also try lowering your voltage and seeing how low you can go. the lower the better. and lower will actually possible make the temps lower at the same speeds also. cuz less volts will be less heat.
good luck and let me know how it goes.
Congrats on OC'n your nice system to be even faster!
edit* sorry this is sooo long.. lol. I'm a talker, or a typer!
Thanks allot , Glad to have you on my side! +repu
I did a test of that prime95 and the result was 56~58c at full load and no errors, I was watching it the whole time so it don't go over 65 when im away.
About the volts in the BIOS I will do what you have told me to and will let you know about the results
Ah man I thought OC RAM's will help but it seems not xD
Will be back with the results!
And thank you again for your effort with me, couldn't do it without you
- Q6600 OCed till 3.3Ghz
- Nvidia XFX nForce 780i SLI
- 2X2GB Corsair DDR2 800Mhz OCed @ 820Mhz
- 2xNvidia 9500 GT SLI OCed @ 730Mhz each.
- Motherboard Built in
- Acer 22' LCD + 18.5 Wide Samsung LCD
- Internal 2x250 GB SATA II Maxtor, External 500GB SATA WD,
- PSU
- 600Watts
- Case
- GIGABYTE
- Cooling
- GIGABYTE Volar CPU Cooler
- Prestigio
- Samsung Pleomax
- 2Mbps
