Solved Need quite a bit of help.
OK, so if I got a 750 watt power supply, wouldn't a be able to get a more powerful graphics card than the 520, or should I stick with it?
    Dell/Inspiron 530
    Intel Core 2 Duo CPU E7400 2.80GHz
    6132MB RAM, 286MB Video RAM
    Intel G33/G31 Express Chipset Family
    1440x900 (32bit) (60Hz)
It's all down to budget at the end of the day & what space is available in the machine.
If you only have one slot available that's the one to get from Nvidia.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Something to keep in mind is that the more powerful graphics cards will have to have larger heatsinks due to heat so you will need 2 slots to fit it in.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Ok, so I'll stick with the 520.
Almost done, yay!
So here's a list of what I should be getting:
GeForce GT 520
Cooler Master RS750-ACAAE3-US (does this come with the power cord included?)
(Possibly) One last question. To install the new drivers and devices, would I uninstall the drivers and devices already on here, turn of the PC, unplug the graphics card, plug in the new one, and then install the new drivers on the site? For the device, would it automatically install when I plug it in?
Also, thank you all so much for all the help. On other sites that I've asked the same questions I've always gotten some sarcastic, uncalled for replies. You were the first people to actually help me. Thanks once again. :D
    Dell/Inspiron 530
Here, we are only too pleased to be of assistance, after all that is what the forum is about.
From the link you have for Newegg, it seems as thought the power supply comes with the power cable.
As for installing the drivers: -
Power off & fit the power supply & graphics card. Check all connections, twice!
Power on & when windows asks for the drivers, say no (Do not use the windows update either) insert the DVD/ CD from the supplier & use their installer.
Once installed & rebooted visit Nvidia & update the drivers on this link.
NVIDIA Driver Downloads - Automatically Detect NVIDIA Products
    40 Meg
Sounds as if this thread is solved but I'm throwing in my two cents anyway:
A 460 watt ATX CoolerMaster is a high-quality unit that I'd absolutely keep a hold of – your system specs make it sound like you have a recent, more than adequate set of hardware components in there: plenty of physical RAM @ six gb and a perfectly decent main CPU on the motherboard.
Dell used to make their PC's so that only a Dell PSU would work in there but stopped playing that rip-off game years ago. But it's always good to double check..
Your 460 watt PSU will easily run an EVGA 520 graphics card and unless you feel an urgent need to upgrade the power supply to a higher wattage, will also save you money on your electric bill. Just remember to get in there and blow out all the dust and crap and keep it clean. That’s one of the best things to do for the longevity of your expensive PC components. I like to stick my hand behind my computer – palm towards the fans about an inch or so away – to feel for the temperature of the air blowing out of the back – it's always cool, almost cold except on the hottest summer days – lol. I have a Seasonic 350 watt PSU that has lots of 'headroom' for running my system - the reason for me getting a new card is because my 2 GB
of RAM and the CPU are being over-taxed by a new install of Vista home premium. I had previously run XP pro for 7 years.
So, all in all, my point is - if you’re set on the 520 graphics card you don’t need to spend any more cash other than on the card. I know cause I just went through all this myself with equipment very similar to yours – and guess what card I bought?
The 520.
Added: And if you have any installation problems with the card or anything else - I'm sure the good folks here on vistax64 will be able to steer you in the right direction - I can be very handy myself - and I'll let you all know how the install of the graphics card goes. Thanks!
    Dell
    Core 2 Duo 2.3 ghz
    Foxconn
    2 Gig Dell/Kingston
    None
    Realtek
    Dell 1907 FP
    1280 X 764
    Seagate 80 gig
    Core2 Duo 2.3 ghz
    Dell
    Seasonic 350 watt Fan
    Microsoft
