My printer does not work
There lies the ironic reason I now use Thunderbird/Lightning, only the compatibility issue was outlook on outlook. I was using Outlook 2000 at home and at work. When I created events with Outlook 2000 at work, and sent the invitations to my home email, they would come in the form of a text email rather than an event and I had to manually re-create the event in my home outlook calendar using the information from the text.
I tried Thunderbird/Lightning just to check it out, and now when I send an Outlook event from work to my home email, Lightning recognizes it as an event and I can simply click "accept" and Lightning auto imports the event into my calendar. Why Lightning will work with outlook, but outlook won't work with outlook, I'm not sure. But that was the reason for my switch and now preference for Thunderbird/Lightning.
I started out using Outlook. When I moved to Vista my version 2000 would no longer function, so started using WinMail. All my contacts from Outlook where easily imported into the contacts folder so everything was working fine. Then when I started testing W7, no winmail. At that point I upgraded to Office 2007 and had Outlook back, which is my preferred client. Don't know about the event thing or whether it's been fixed, as I never have used it. I work alone at home so never needed it.
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
