Indulgence
2 Months ago, my internet was fine and I would always get a constant speed when downloading and playing games. My ping usually in some games like CSS would be 40-50. But one day, my ping started jumping from 60- 150 and my download speed spikes from 67 kb/s to 300 kb/s.
I scanned for viruses etc. but still no luck. I EVEN REFORMATTED MY PC. Still no luck.
Here is a log of me pinging to Google in command prompt
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\***** ***Ros>ping Google -t
Pinging Google [64.233.169.147] with 32 bytes of data:
Reply from 64.233.169.147: bytes=32 time=139ms TTL=245
Reply from 64.233.169.147: bytes=32 time=109ms TTL=245
Reply from 64.233.169.147: bytes=32 time=86ms TTL=245
Reply from 64.233.169.147: bytes=32 time=49ms TTL=245
Reply from 64.233.169.147: bytes=32 time=59ms TTL=245
Reply from 64.233.169.147: bytes=32 time=138ms TTL=245
Reply from 64.233.169.147: bytes=32 time=101ms TTL=245
Reply from 64.233.169.147: bytes=32 time=137ms TTL=245
Reply from 64.233.169.147: bytes=32 time=82ms TTL=245
Reply from 64.233.169.147: bytes=32 time=52ms TTL=245
Reply from 64.233.169.147: bytes=32 time=47ms TTL=245
Reply from 64.233.169.147: bytes=32 time=79ms TTL=245
Reply from 64.233.169.147: bytes=32 time=70ms TTL=245
Reply from 64.233.169.147: bytes=32 time=149ms TTL=245
Reply from 64.233.169.147: bytes=32 time=69ms TTL=245
Reply from 64.233.169.147: bytes=32 time=89ms TTL=245
Reply from 64.233.169.147: bytes=32 time=67ms TTL=245
Reply from 64.233.169.147: bytes=32 time=73ms TTL=245
Reply from 64.233.169.147: bytes=32 time=50ms TTL=245
Ping statistics for 64.233.169.147:
Packets: Sent = 19, Received = 19, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 47ms, Maximum = 149ms, Average = 86ms
Control-C
^C
C:\Users\******>
As you can see, it spikes every few seconds. I tried resetting my router, even connected directly to my modem, and still I persist in spiking.
So if you can help me, please do as I would appreciate your aid.
Control-C
^C
C:\Users\******>
- Intel Pentium D 3.0 Ghz
- 1 gb
- GeForce 8500GT
- Sound Blaster X-Fi Extreme Audio
- eMachines HD 17 wid TFT LCD monitor
- 1280 x 720 native
- Cooling
- fan
- Wheel mouse optical USB
- eMachines standard keyboard
- Rogers ultra light 512 KBps
