You should upgrade or use an
alternative browser .
My DVD burner won`t read blank Verbatim DVDs
Have you by any chance got Nero installed? If so is InCD installed? If so that could be the cause as InCD should never be installed in Vista or Windows 7 as it is incompatible with the OS's own CD/DVD handling keys.
I do have Nero 7 installed. How do I check if InCD is installed? Is it a Nero application?
I am looking now in my Nero file, at the Start Menu, & I can`t see anything with that name.
I installed an update over a year ago, as well: Nero 7.11.10.0 all update
Asus Z53E series
DUO T8100
M/B Version: F3E
2GB
15.4" WXGA
160GB
Rainbow USB
10MB
MATSHI/TA DVD-RAM UJ-841S ATA device
If you're going through hell, keep going
In your Start/All Programs menu there should be an entry for Nero Control Center - call that up and it should be shown as (hopefully) not installed in that.
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
1 external eSATA LaCie 3TB
(Non-RAID)
Unique
1gb/s up and down
Yeah, I did that, & it took me to the screen where Nero`s program gives me the choice to burn a Data cd/Dvd.
As well, in the start menu, I type Nero incd, & it is there. So, it seems like it is installed.
How is that I never had a problem with this for a whole year? Is there anyway I can make it compatible with Vista or should I just get rid of Nero all together?
This is a screenshot of what appears:
Asus Z53E series
DUO T8100
M/B Version: F3E
2GB
15.4" WXGA
160GB
Rainbow USB
10MB
It's been awhile since I used Nero Essentials.
Is Nero Startsmart listed in your Start/All programs when you expand the Nero section?
I have Nero 9 so it's difficult to remember navigating Nero 7 but if you could call that up it should list by name all the programs included.
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
Yeah, when I expand the Nero section, I get:
Nero online upgrade
Nero product Setup
Nero Startsmart essentials
-Audio
-Data
-Labels
-Manuals
-Photo & Video
-Play
-Tools
Do you prefer a screencap that shows what`s inside the folders as well, or is that alright?
Asus Z53E series
DUO T8100
M/B Version: F3E
2GB
15.4" WXGA
160GB
Rainbow USB
10MB
It doesn't list components by name? For example nero express, nero burning rom etc.
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
Is this what you need?
Asus Z53E series
DUO T8100
M/B Version: F3E
2GB
15.4" WXGA
160GB
Rainbow USB
10MB
InCD isn't installed so that theory is out.
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
Ok. So, it seems like there`re two less possible reasons.
I was wondering wether the Cd lens & the Dvd lens are the same. What I mean is, because it reads bland Cds without problems,but not Dvds. does that mean that it`s definitely not that my lenses need a good clean?
Asus Z53E series
DUO T8100
M/B Version: F3E
2GB
15.4" WXGA
160GB
Rainbow USB
10MB
I think they only use 1 lens.. Blu-Ray burners use 2.
It's possible that the burner is simply broken and should be replaced. Do you know anyone who could perhaps lend you one of theirs to try, just to see if Vista sees it?
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
Do you mean the whole CDDVD drive? I don`t know anybody that has a separate burner, if I get you right. I`ve got a laptop myself.
If Vista recognizes another burner, then that would mean that my burner is broken, right?
Asus Z53E series
DUO T8100
M/B Version: F3E
2GB
15.4" WXGA
160GB
Rainbow USB
10MB
I meant to try swapping out the drive with another one. Or I suppose you could try connecting an external DVD burner. If Vista recognizes it then the installed one has to be broken.
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
