MSI R4890 Cyclone OC question
i am using CCC and MSI afterburner. Currently i have it running at 900 Core MHZ and the memory at 1110 MHZ x4
im thinking i cant get the core any higher because of the voltages how do i unlock the card to tweak the voltages?
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
hm....... smart? this is your area of expertise.....
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
what do u mean? this card is a beast its made for overclocking i just need to give the card more voltages for the core, it bottle necks past 910
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
smart is short for smarteyeball; a member of this forum. He will be able to help you out here
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
oh well i need to figure out how to mess with the voltages cause this card bottle necks if i try to go past 910 it shuts down and turns back on and shortly after windows 7 restores it
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
yes.... if he reads this.... he is quite good with all that.... i've never done it myself so.... haha me telling you how isn't a good idea ;)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
your gonna need to do a (volt/BIOS mod) to go above this, ive never done one or even researched it really, but many do it on the 4890s with great results....
just hunt down some ''4890 volt mod'' info off the web, then take it from there.... by the looks of it you've done well already without the mod, i cant see the clocks going much higher than they are right now even with more volts....:)
(though im no ATI expert :p)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
im looking into this atm and it seems pretty dangerous atm im using ATI RBE but im kinda confused on how to use it i just wana tweak this thing to where its stable at 1ghz core clock and 1110mhz memory clock
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
im going to need some help can some one give me a link to smarts profile so i can message him? i need his help if hes the master at this
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
    1680 X 1050
    6 Mbs Down 1 Mbs Up
The difference between most factory overclock cards and the lower end models are the voltages applied in the BIOS.
The reason some cards are sold as higher clocked versions is because they are 'better binned' or in other words, have better quality chips which can handle the higher voltages. Those cards that can't handle the higher volts are sold at lower speeds. That is why there is no guarantee that you can achieve the same stable clocks as the OC'ed models.
Anyway...
Before committing any settings in the BIOS permanently using RBE or rivatuner, I'd suggest using GPUtool to test various clocks and voltages first to find what the card can do:
techPowerUp! :: Download GPUTool Community Technology Preview 1
The max 'safe' voltage for the core (VDDC) is between 1.4 / 1.45 - however this is entirely dependent on how effective the cooling is. Don't jump straight to the max 1.45 - In fact I would use 1.4000 as your max 'safe' voltage to begin with. You don't want to fry/cook your card while attempting this.
GPUtool doesn't permanently apply settings, but you can save profiles. This is important for testing in case you set something that the card can't take. The downside is that you have to manually apply the profile every time you start Windows.
Basically you just set the core/mem clocks under the clock tabs and set the voltage (VDDC) under the voltage tab. I set the fans speed manually with CCC.
Use GPU-Z to monitor the temps:
techPowerUp! :: Downloads
Another method would be to download and flash the BIOS from the SOC version - but this method has it's risks. A bad flash or if the card can't take the OC settings - can brick a card.
Another method is to use rivatuner. I haven't personally used rivatuner to adjust settings, so I can't vouch for it, but this guide may also help:
Overclocking the Radeon HD 4890
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
there he is.......:)
if anyone can void the warranty ...Smarty can ;)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
lol, warranties are made to voided :p
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
thanks smarty i am already into the bios its just that the program is confusing lol ill send u some screenshots of what i have.
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
Here are the pictures, in one of them i circled something i saw is that even possible?
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
It's possible if a cable isn't connected properly. It may be worth double checking both plugs are fully secure.
Otherwise, it may be just a bug where it's incorrectly reading a sensor.
Is that your stock BIOS?
EDIT:
Ignore the warning
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
i checked they are both on and i guess i should grab a electric sensor and see what the wattage is on them it could be the power supply. Also yeah thats the stock settings im a total noob with this program if u could help me do my voltage perfictly that would be great.
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
if you like smart lets talk on AIM or MSN and we can get this card running right i can even let u remote connect i don't want to fry this card its the MSI Cyclone it has a huge ass heat sink and military components
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
Sorry mate, I don't AIM or MSN.
For the time being, until you know what volts and clocks are 'okay' I'd suggest you'd leave RBE alone for the time being and use GPUtool instead.
It's simpler, quicker and with less risk of borking your card.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
