Solved Memory Usage 50% at Idle
Don't type, just copy/paste.
Why copy paste when I just double click a shortcut?
Target line for shortcut
C:\Windows\System32\cmd.exe /k SetRestorePointMax.cmd
I don't know how this thread got onto how I run my commands. It seem irrelevant to me.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
You are right - everybody has their own method. No harm done.
    Dell
    Q6600
    HP w2207h
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Depending upon how much ram you have 50% isn't bad. I have 2 gb and Vista is usually using 55-60% and I turn services that I don't need off. Windows 7 really uses less in my experience. It really isn't anything to worry about. Now I would worry if consumptions is usually nigher than 90% because you don't want to run out.
You are a lucky man. At least half of the RAM you paid for is being used, LOL.
But seriously, you have no problem. With a small RAM of 2GB I would not expect any different. If it bothers you, install more RAM. The Dimms are cheap these days.
I have the opposite problem. My RAM is hardly being used although I paid good money for it.
This is precisely why I don't have an insanely high amount of ram. IMO most people don't need more than 4.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I downloaded and opened RamMap but I can't really make sense of it. Anyone know what I should be looking for and where?
Edit: Do I look under File Summary and then look at Total (which seems to be size) in descending order?
Thanks.
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
I call shenanigans. If you can't figure it out from the screen shot on the download page, I give up.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Your screenshots do not say how much memory you have. Just what percentage is used.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
