This isn't a Driver Verifier enabled memory dump.
But it does blame SuperAntiSpyware. Please uninstall it.
Also, it seems that Daemon Tools is installed. Although it's not a common problem with Vista, I'd recommend removing it anyway. Please follow the instructions here:
If, after removing this stuff, the BSOD's continue - please run Driver Verifier again according to these instructions: http://www.carrona.org/verifier.html
Further info on BSOD error messages available at: http://www.carrona.org/bsodindx.html
The following info is just FYI, I've already addressed the issues that I saw in the above paragraphs
3RD PARTY DRIVERS PRESENT IN THE DUMP FILES
http://www.carrona.org/drivers/driver.php?id=kl1.sys
http://www.carrona.org/drivers/driver.php?id=UBHelper.sys
http://www.carrona.org/drivers/driver.php?id=ahcix86s.sys
http://www.carrona.org/drivers/driver.php?id=AtiPcie.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=yk60x86.sys
http://www.carrona.org/drivers/driver.php?id=NTIDrvr.sys
http://www.carrona.org/drivers/driver.php?id=SASKUTIL.SYS
http://www.carrona.org/drivers/driver.php?id=RTKVHDA.sys
http://www.carrona.org/drivers/driver.php?id=klif.sys
http://www.carrona.org/drivers/driver.php?id=kl2.sys
http://www.carrona.org/drivers/driver.php?id=klim6.sys
BSOD BUGCHECK SUMMARY
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please uninstall the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): DuplexSecure - FAQ
Some free alternatives (I don't use them, so I can't comment on them)
KernSafe iSCSI initiator, Virtual CD/DVD-RW Emulator, Virtual Encryption Disk and Virtual CD/DVD-ROM Emulator All-in-One free software.
MagicISO - Convert BIN to ISO, Create, Edit, Burn, Extract ISO file, ISO/BIN converter/extractor/editor
Code:
[font=lucida console]
[Color=Red]spbj.sys Wed Mar 05 19:32:57 2008 (47CF3BB9)[/Color]
kl1.sys Wed Jun 09 09:24:39 2010 (4C0F9617)
[Color=Red]UBHelper.sys Wed Jan 30 20:30:26 2008 (47A124B2)[/Color]
[Color=Red]ahcix86s.sys Fri Mar 07 08:15:58 2008 (47D1400E)[/Color]
[Color=Red]AtiPcie.sys Mon Oct 30 14:23:10 2006 (4546430E)[/Color]
[Color=Red]atikmdag.sys Sat Aug 30 01:12:57 2008 (48B8D6D9)[/Color]
[Color=Red]yk60x86.sys Thu Dec 06 07:25:16 2007 (4757EA2C)[/Color]
[Color=Red]NTIDrvr.sys Wed Jan 30 20:30:42 2008 (47A124C2)[/Color]
SASKUTIL.SYS Tue Jul 12 16:24:48 2011 (4E1CAD90)
[Color=Red]RTKVHDA.sys Tue May 20 05:58:56 2008 (4832A0E0)[/Color]
klif.sys Fri Aug 06 13:16:02 2010 (4C5C4352)
kl2.sys Wed Jun 09 09:24:35 2010 (4C0F9613)
klim6.sys Thu Apr 22 11:07:20 2010 (4BD06628)
[/font]
Code:
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini042012-01.dmp]
Built by: 6002.18595.x86fre.vistasp2_gdr.120305-0430
Debug session time: Fri Apr 20 06:02:01.070 2012 (UTC - 4:00)
System Uptime: 0 days 0:00:15.116
*** WARNING: Unable to verify timestamp for SASKUTIL.SYS
*** ERROR: Module load completed but symbols could not be loaded for SASKUTIL.SYS
Probably caused by : memory_corruption
DEFAULT_BUCKET_ID: CODE_CORRUPTION
PROCESS_NAME: System
BUGCHECK_STR: 0x7E
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE
Bugcheck code 1000007E
Arguments c0000005 8e5dd503 80399904 80399600
[/font]
