niemiro
Banned
Hello,
Sorry for the late reply. Something happened, but back now! Don't worry about being on and off line, just post when you are ready!
If you feel confident, you could remove the hard disk, put it in another computer, and backup your files. However, there is another, easier and safer method
The easiest method is to download and run a Linux Live CD. There is a good tutorial using Ubuntu here: Use Ubuntu Live CD to Backup Files from Your Dead Windows Computer - How-To Geek
The interface is similar to Windows, but not exactly the same. Use the method of backing up the files to USB rather than Windows Network, as this is SO much simpler.
If you cannot cope with Linux, there is another way that uses a more Windows like interface, though setting it up requires a Windows CD, several downloads, some special commands, and some hacking. It is not quite as easy, but I can give you a guide if you struggle at all with Linux.
Alternatively, without such big downloads, if you can tell me exactly where all the files you want to backup are, we can do it through DOS, though I would not recommend this.
Good luck, and I will help you with the Clean Install once we are sure all of your files have been backed up!
Richard
Richard
- Dell XPS 420
- Intel Core 2 Quad Q9300 2.50GHz
- Stock Dell 0TP406
- 4 gb (DDR2 800) 400MHz
- ATI Radeon HD 3870 (512 MBytes)
- Onboard
- 1 x Dell 2007FP and 1 x (old) Sonic flat screen
- 1600 x 1200 and 1280 x 1204
- 1 x 640Gb (SATA 300) Western Digital: WDC WD6400AAKS-75A7B0 1 x 1Tb (SATA 600) Western Digital: Caviar Black, SATA 6GB/S, 64Mb cache, 8ms Western Digital: WDC WD1002FAEX-00Z3A0 ATA Device
- PSU
- Stock PSU - 375W
- Case
- Dell XPS 420
- Cooling
- Stock Fan
- Advent Optical ADE-WG01 (colour change light up)
- Dell Bluetooth
- 120 kb/s
- Other Info
- ASUS USB 3.0 5Gbps/SATA 6Gbps - PCI-Express Combo Controller Card (U3S6)
