Is it just the web browser that stops working, or the whole laptop?
Have you already reset IE to see if that helps?
Does it still do this when you have the laptop plugged in vs not plugged in? It may be a Power Plan setting that reduces the wireless adapter power for signal strength or turns it off if the battery gets low.
If none of this checks out, then you may consider reinstalling Vista on his laptop as well.
- Operating System
- Windows 10 Pro 64-bit
- Custom
- Intel i7-8700K 5 GHz
- ASUS ROG Maximus XI Formula Z390
- 64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
- ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
- Integrated Digital Audio (S/PDIF)
- 2 x Samsung Odyssey G7 27"
- 2560x1440
- 1TB Samsung 990 PRO M.2, 4TB Samsung 990 PRO PRO M.2, 8TB WD MyCloudEX2Ultra NAS
- PSU
- Seasonic Prime Titanium 850W
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Logitech MX Master 3
- Logitech wireless K800
- 1 Gb/s Download and 35 Mb/s Upload
- Other Info
- Logitech Z625 speaker system, Logitech BRIO 4K Pro webcam, HP Color LaserJet Pro MFP M477fdn, APC SMART-UPS RT 1000 XL - SURT1000XLI, Galaxy S23 Plus phone
- Operating System
- Windows 10 Pro
- HP Envy Y0F94AV
- i7-7500U @ 2.70 GHz
- 16 GB DDR4-2133
- Conexant ISST Audio
- 17.3" UHD IPS touch
- 3480 x 2160
- 512 GB M.2 SSD
