Little help please folks.. cant move/rename some vid' files...
Hi Again,
Everything that I have suggested so far has either been used by me or it was used by other members with success. I truly do not like making suggestiions,when I am not sure of the potential problems.
Read this information, if you think it applies to your situation and it may help, make a sytem restore point, in case of problems, then try it..
I submit this for your consideration, so that you know that the method exists and that it is available to try.
http://www.vistax64.com/tutorials/130137-cannot-rename-move-file-folder-vista-fix.html
I cannot understand why nothing seems to work.
Try to right click on one and send to desktop. If you get it there see if you can move and rename etc. The desktop is like a folder.
Try to copy and paste, see if that works.
Try to turn off your video player, see what happens..
These ideas may not work, as I am guessing, now.
they were the first few things I tried and checked.. u see now why I'm cracking up with this? lol.. nothing is working like, its driving me demented :(
I think you know, Paj, I really want to sort this out, but I am running out of ideas. I will do some research and post as I find answers that may help. Keep checking for information from me as well, as others who may offer help.
oh, and the 2nd one, there doesnt seem to be a gpedit.msc... just a .dll file...
***I just realised why, its not available in vista home***
Ack, I can do it through the reg... I'm fair tired... :s
O.k, I'm starting to give up meself... I tried to download the reg edit to allow the user profile folder change thingy.. but it wouldn't download for me.. lol... It just aint meant to be!!! Richard man, thanks for putting up with it this long, I REALLY appreciate it, and if you do think of anything else, please feel free to let me know! lol! thanks again mate :
I will think about this and really try to solve it. I know that the solution is so easy that we both miss it. Just check now and then for any answers. If you do not forget about me, I will keep your thread in mind.
OK, here is my thought for today. Your first post indicates that you are having a problem with certain folders; both you and I have concentrated on the folders and have gotten nowhere.
How about this. There may may be corruption in your system.
Go to search, type cmd (do not hit enter), right click on CMD and run as administrator. In CMD type sfc /scannow. This will list and fix any corruption. If errors are found, try it several times it fixes only one error at a time. If you do this, then try moving the files again.
success! havnt been able to post anything since my last post... kept telling me that my posts where to short and had to be at least 3 characters long... ha!
o.k, basically, tried EVERYTHING now at this point, and still having no luck.. so I pretty much give up. Thinking of backing up everything and buying me a copy of Windows 7 to be honest... but I dont know...
What is the brand or your lap top?
If you want to buy 7, it is a great OS. If you want to salvage what you have, there are still several ways.
Its actually a PC I'm using - a HP a6305.uk ...nothing special like, just an off the shelf thing. tbh, I'v been wanting to get a few new bits for it, but I aint evn sure whats upgradeable on it.. keep meaning to check.. but I never think of it when I have time.
The reason that I ask about the computer is because, rather than buy Windows 7. You can try this. Restore to factory specs. If it works you will be like the day you brought the computer home. You have to reinstall all programs etc, but you will be working again. Windows 7 is great, however.
Laptop Recovery Instructions - Tech Support Forum
The instructions might be a bit different, since it is the UK, but the method will be in your manual or on line and I can help, too.
I did consider that alright.. but I figure, if I have to go through the hassle of doing that (and having to back everything up and all), I might as well just go and buy the new OS.. well, depending on how much it is...I know I can get it "other" ways.. but I think I'll actually go buy it if I do want it...
