As a possible way to save what I have on my harddrive, I've now got a hard drive docking station -> CnM Lifestyle Products - Technology for everyday people!
I was hoping that I would be able to just plug it all in to my spare PC and I'd be able to access my files from the laptops harddrive. However it's not working, the PC recognises that the doking station is connected but I can't access the files.
When I go into My Computer and click what is supposed to be the laptops harddrive, I's just asks if I want to format it.
I'm not sure where I'm going wrong.
I hope that helps.
Ok I think I am with you, you are trying to copy/save from the docking station to your external or your second PC. Is this right?
Do not format your lappy HDD this will definitely destroy all data on it
Does the HDD from your external fit in the Docking station this might be a way to test it. Your lappy HDD might be the problem as it should show straight away.
Pooch
- Self build
- Phenom II x4 Black Edition 940-Arctic-Cooling Freezer Xtreme
- Asus M3A32-MVP Deluxe
- 8 gig Samsung PC800 RAM
- NVidia 9600gt
- AD1988b
- 22" TFT-MONITOR WIDESCREEN mit VGA/DVI 17" Video7 TFT
- 1680 : 1050 1280 : 1024
- Drive #1 - SAMSUNG HD252HJ (250 GB) Drive #2 - Hitachi HDT721010SLA360 (1000 GB) Drive #3 - SAMSUNG HD250HJ (250 GB) Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
- PSU
- Thermaltake Toughpower Cable Management 750W
- Case
- Enermax Chakra
- Cooling
- 2x 120mm Front and Back 1x 250mm Side
- Easy Line Laser Mouse
- Standard
- Other Info
- I have also used Fedora, Suse, Ubuntu Linux And all other Windows from 95 to date except ME
