Hi, I was wondering if anyone could help.
My laptop (Advent 8117 running Vista if that helps) has been working fine, then this morning things went pear-shaped. To begin with things worked as usual - Everything seemed to load up as normal, I left the room for maybe 5-10 minutes and when I returned there was a black screen. I waited a while and nothing happened so I restarted.
It comes up with 'Windows failed to start. A recent hardware or software change might be the cause.'
From there I can either start normally or run a repair.
It doesn't seem to matter what I click here because I get a 'Techguys' support thing come up either way but now nothing on it works. To begin with I ran the Repair Environment, but it couldn't fix it. I also got to try a System Restore but I seem to have no points to restore to.
Now I can't get the Techguys page to do anything. So I tried running in Safe Mode but once again I'm faced with the unmoving Techguys page, and the same goes for when I try and load from the Last Know Good Configuration.
I desperatly don't want to have to lose everything.
Any help on this would be much apreciated. I have no idea when it comes to this.
Thanks!
Thanks!
Would it be bad to use the wrong one?
