laptop randomly shuts down not overheating
In a laptop anything can overheat.That flame symbol is a sign of overheating and should be looked into more.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
or risk losing the computer
OK, so then where do I go from here? I"v read about people "reapplying thermal paste" and that solves the problem. I've never tried tried, so should I? And what if it keeps over heating? How do I choose the right thermal paste and what are the differences between thermal pastes if there is any? someone educate me! Lol.
Here is the snapshot after I had wipped everything:
http://i84.photobucket.com/albums/k34/dragonpoet88/temp-1.jpg?t=1298985390
Ok, so I am working on a laptop for my buddy's wife. It is a hp pavilion dv9700. Obviously enough the title explains it all. I have blown canned air through it and it seemed to run for about 3 hours in safe mode while I defraged it. Logged back on and tried to preform update to sp2 and crashed in the middle. Luckily it turned out just fine. I don't believe it's due to overheating because the bottom and the keyboard aren't hot, at least not compared to any other laptop. I have tried to replace the memory and it still happens. Anyone have any ideas? I'm so stumped. SystemInfoEdited.jpg picture by dragonpoet88 - PhotobucketHere is a link to her system Info. I had to edit it because she used her first and last name as the user. And also she actually has 4gb of ram installed, there is just 3 because I tired to replace it with my own as previously stated. Well, thanks for the help in advance.
P.S.
I have read some stuff where its the thermal paste. How would I go about replacing that?? And is that a symptom of anything?
P.S.S.
And when I say "shutting down", it shuts off. No log off screen, no BSOD (blue screen of death), just off.
P.S.S.S.
And It's not when it's normally running when It's shutting off. It's shut off in safe mode and I have even seen it shut off on the screen where is says "press F2 to blah blah blah" when you first turn the laptop on.
:devil:Ok as Much As I hate to tell you but my fiancees brother had this same laptop. well he did some reserch. it was hp's fault something is warped inside and its a pain to fix because the whole thing must be striped. sorry to tell you this.:devil:
    Emachine
    768 ram 200 Gb hdd
Not necessarily
Try with the pad first, if not good enough you can go with the paste. Try one thing at a time.
Im giving you the advice that I would take. Try one step at a time. If the pad does not work, you can try paste. Dont know if you saw it in my ariticle, clean the inside. That is the most common cause of overheating.
