yes but when i right click the is no option to run as admin, there is only:
open
pin to start menu add to quick launch
send to ->
cut
copy
create shortcut
delete
rename
properties
it runs as you said i t should until it comes to the log file
where i am greeted by a message saying:
cannot find the C:\Program Files\ Trend Micro\HiJackThis\hijackthis.log file
do you want to create a new file?
yes no cancel
no matter which of those i click it stays blank
i have also tried creating that file manually
and re-installing it
Where have you downloaded HJT to? Is it in C:\Program files? If so, look in the folder C:\Program Files\ Trend Micro\HiJackThis and see if there is an icon that looks like notepad. That will be the HJT log. Just copy and paste the contents.
1 x 640Gb (SATA 300)
1 x 1Tb (SATA 600)
Stock PSU - 375W
Dell XPS 420
Stock Fan
Dell Bluetooth
120 kb/s
