Internet issue (local connection )
    Dell inspiron 546 desktop
    AMD Athlon 7550 dual core 2.50GHZ
    Dell 0F896N
    3GB DDR2 SDRAM 800MHZ- 3X1GB DIM M
    ATI Radeon HD 3200
    Sanyo
    1024x768
    500GB NCQ Serial ATA Hard Drive (7200 RPM) w/ 16MB DataBurst Cache
    625 Kbps
Modem firmware was going to be my next suggestion... Already advised ^^^ :)
How are you connected, do you have to 'sign in' to access the internet? Like an email and password?
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
Im supposed to be automatically connected with no sign in.I have a old westell 6100 i might try..this one is the newer version and I noticed it has a bit more issues related to it.
For now I guess I'll try calling Verizon (that should be tons of fun)
Thanks everyone for helping :)
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
Post back if the old modem doesn't drop. :) In fact, post back with any results, please :)
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Yep. A new modem and all your problems will be solved! :)
Good luck!
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Update.
Well I gave them a call they couldn't figure anything out (as i figured )
They are sending a new modem so we shall see what happens with that.
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
Update.
That's good. Obviously there is something screwy with yours. Keep us posted :)
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Excellent. Sounds like your modem was old and hopefully the new one will have you cruising the Internet Highway again! Good luck!
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Got the new modem 2 days ago and I am having the same exact issues.I've contacted just about everyone and they are all stumped.Guess I'll be getting used to the restart button alot.:sa:
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
Oh No!
What if you type at the command prompt..
c: ipconfig /release
c: ipconfig /renew
If this works, we might be able to set up a batch file/icon instead of shutting down the pc. This is not a good solution, but it's better than restarting.
Lemme know if it works...
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Thanks I'll have to try that.
I've come to the conclusion it's just Vista messing up somewhere with the TCP.The first time it went to local with this modem,I diagnosed and repaired (right click) And it said that vista needed to set up some kind of automatic TCP I believe.It worked that way just once.Now it's back to "vista can't find a issue with your connection"If i would to right click the icon.
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
Here is your batch file to renew your ip address. Just click and go :)
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Thanks Lemur :D
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
Constant local connection issues
Im running Vista home basic 32bit
I'm connected to DSL through a westell 6100 wired modem via Ethernet port.
After about 3 months of owning this computer I started having problems with my internet connection.Randomly my connection would switch to "local" and my browsers would fail to connect to the web but a application like AIM would still connect.I tried disabling my connection then re enabling it,refreshed ip,flushed tcp etc etc.I reset my modem turned off ip6.And after many calls to my internet provider I ended up getting a new modem sent to me and I formatted and reinstalled Vista and nothing has worked.
Basically I have to do a full restart to correct the local only issue only for it to happen again and again.
I ipconfig/all today and i noticed it said "media disconnected" I'm not sure if this could be the problem? I have seen many people having the local connection problem with wireless but I'm wired.
Here's the ipconfig/all log.
Anyone have any ideas to what the issue is?
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : westell.com
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : westell.com
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 00-24-E8-20-32-5A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.15(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, October 17, 2009 1:48:31 PM
Lease Expires . . . . . . . . . . : Sunday, October 18, 2009 2:47:03 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.westell.com
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
still having the same issue i give up..guess i'll be saving up for windows 7 i mean it has to be vista???
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
Guys I'm no expert but I had identical problem. Firefox works fine then randomly stops altho it is still running in Task mgr. Cant close the process down from there and have to reboot. Problem got worse over a couple of weeks and was happening every time - also happened with IE 8 and Opera, nad in thelast few days if one went down the others were locked up too. I use Zone Alarm - have done for years with XP without a hitch. I couldn't find anything anywhere online that helped - but I eventually found a suggestion that I change to another Firewall. I switched to PC Tools Firewall and (for the last two days at least) not a problem. Both Firefox and IE seem to be working perfect. Hope that helps - cos I know how frustrated I was getting. If it doesn't work at least it shouldnt cause any more problems, and even a non techie like me can try this. Good luck.
    HP
    AMD phenom 9750 Quad core 2.4 ghz
    ATi radeon hd 4350
    Realtex High def
Yea i had that issue using zone alarm and now Im currently using pc tools..But this isn't a firewall issue it happens with it off too.I guess nobody has any ideas i tried everything to try to fix this looks like I'll have to deal.
    Dell 0F896N
    ATI Radeon HD 3200
    Sanyo
    1024x768
    625 Kbps
