Internet Explorer - Maximum Download Sessions
How to Change Maximum Download Sessions in Internet Explorer 7
This will show you how to change the number of simultaneous downloads from a web server to what you set them to for only the current or all user acounts. 10 is usually a good maximum. 2 is the default maximum.
  • The current HTTP specification limits the number of simultaneous file downloads to two downloads, plus one on stand by. As connection speeds increase, the number of simultaneous downloads to a single web server may not be enough for your needs.
  • If you visit a web page with lots of images (and supporting files like CSS styles and Javascript), then you can have a slower browsing experience. On average, your browser would have to make more than 40 requests to the server before it can assemble the complete page. Requesting all the files you need with the default 2 at a time is going to be slower than requesting say 10 files at a time.
This will work with any other web browser you are using as well. For example, FireFox.
OPTION ONE
For the Current User Account Only
Using a REG File Download:
Current User 10Max.reg
download
2. Click on Save and save the .reg file to the desktop.​
3. Right click on the downloaded .reg and click on Merge.​
4. Click on Run, Continue, Yes, and OK if prompted.​
5. Log off and log on, or restart the computer to apply the changes.​
6. When done, you can delete the downloaded .reg if you like.​
Manually in Registry Editor:
1. Open the Start Menu.​
4. In regedit, go to: (See screenshot below step 5)​
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
5. In right pane, right click on a empty area and click on New and DWORD (32-bit) Value.​
6. Type MaxConnectionsPer1_0Server and press Enter.​
7. In right pane, right click MaxConnectionsPer1_0Server and click on Modify. (See screenshot below)​
8. Dot Decimal, then type 10 and click on OK. (See screenshot below)​
NOTE: The default value is 2, but you can change it to your needs.
9. Repeat steps 5 to 8 above, but use MaxConnectionsPerServer instead now.​
10. When done you should see this below boxed in red.​
11. Close regedit.​
12. Log off and log on, or restart the computer to apply the changes.​
OPTION TWO
OPTION TWO:
For All User Accounts
All Users 10Max.reg
download
  • All Users 10Max.reg
    All Users 10Max.reg
  • Current User 10Max.reg
Can I just delete those two (16) entries from the registry?
    Dell Inspiron 530
    Intel Core 2 DuoE4500 2.20G
    3.00G DDR2, 667MHz
    Intel G33/G31 Express 320
    Realtec ALC888 (7.1 Channel audio)
    Dell 22" E228WFP
    Samsung HD501LJ ATA 500 G PBDS DVD+RW DH-16W1S ATA MAXTOR 320 G USB
    5.28 Mb/s Down, 0.64 Mb/s Up, ATT Dry Loop DSL
Hdbg62,
MaxConnectionsPer1_0Server REG_DWORD 0x0000000a (10)
MaxConnectionsPer1_0Server REG_DWORD 0x00000010 (16)
MaxConnectionsPerServer REG_DWORD 0x0000000a (10)
MaxConnectionsPerServer REG_DWORD 0x00000010 (16)
If you have all 4 of these in that one location, then yes delete the ones with (16). Check the names of the ones with (10) after deleting the (16) ones to make sure that there is not a space included at the end of the name. You can see if they do by right clicking on them and click Rename. One of these sets had to have had a space in the name included for you to have 2 of them with the same name.
Yep, they're all in the same location. I deleted the two with the (16) value, restarted and checked the name on the ones left with the (10) value, no extra space visible and the cursor is right at the end of "Server". All seems to be o.k. and in any case, for once I did not get too much in a hurry and backed up the registry should I need it. Thanks for your time, Brink.
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
Your welcome Hdbg62. I'm glad to hear that you got it all sorted out now.
That's really noticeable faster,thanks for the awesome infos~~~Brink
~Peace~
    XPS 720 RED
    Intel® Core™ 2 Extreme QX9650(Penryn Yorkfield) ([email protected])
    8GB OCZ Reaper PC2-8500 Ver.3@1066MHz
    EVGA GeForce® GTX 295 Plus w/Backplate OC@ 670c/1246m/1500s
    Sound Blaster® X-Fi™ XtremeGamer (D) Sound Card
    Dell Ultrasharp 27" WFP LCD
    1920X1200
    500GB - Seagate 7200RPM, SATA 3.0Gb/s, 16MB Cache with Thermaltake HDD cooler ~ Western Digital 1TB X (5) / 750GB USB 2.0 My Book Essential Edition 2.0 External Hard Drive
    1,000W
    XPS 720 Sliver w/ X-View Clear Side Panel
    Logitech® MX™ Revolution Cordless Laser Mouse
    Logitech® diNovo Edge™
    15MB~D/2MB~U
    Logitech® Z-5500 THX-Certified 505-Watt 5.1 Digital Surround Sound Speaker System ~ D-Link DGL-4500 Xtreme N Gaming Router ~ Scythe KAMA-METER 5.25 inch Bay Multi-Function Panel Controller ~
Your welcome Abiosis.
Hello Shawn,
my question is about the following tweek;
"How to change the maximum Download Sessions in Internet Explorer for Vista"
Step #5. "In right pane, right click on a empty area and click on New and DWORD (32-bit) Value."
My OS is Vista x64 should I chose "(64-bit) Value" ?
Thanks for your Time and all of your hard work
Mitch
Hi Mitche, and welcome to Vista Forums.
No, it will still be the DWORD (32-bit) Value option for the 64 bit Vista to.
LOL, service with a smile. :geek:
Your welcome Mitch.
Your welcome Dabusta, and welcome to Vista Forums.
