Intel chip patch?
Try WLAN Optimizer. This little program disables some "feature" in Vista that periodically checks for stronger networks in your area. Every time Vista checks for a better network, it will pause and cause some lag in online games. I installed it, and I haven't had anymore problems with my wireless.
You are a life saver thank you I recommend that,! problem solved!
    Customized
    Intel Q6600
    P5Q Pro
    6 gigs
    XFX GTX260
    on board
    RCA 27", Viewsonic 19"
    1168x664
    456 gigabytes
    600 StealhXstream
    NXZT hush
    Fans
    Razer DeathAdder
    Razer Lycosa
    Don't know
Do you mean public networks or your neighbors unprotected, non-secured wireless router?
    16GB DDR667
    SAS RAID
My mother has set up a Private Internet connection, and thanks to that link he provided me the problem is resolved thank you all,
    Customized
    Intel Q6600
    P5Q Pro
    6 gigs
    XFX GTX260
    on board
    1168x664
    456 gigabytes
    600 StealhXstream
    NXZT hush
    Fans
    Razer DeathAdder
    Razer Lycosa
    Don't know
Interesting fix. I will have to remember that.
    16GB DDR667
    SAS RAID
I really don't remember how I came across that little program, but I was having your same problem and frustration. I'm very glad it worked out for you. :)
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    4x1GB Crucial Ballistix DDR2 800
    PNY 8800GT @ 675/1675/950
    Asus Xonar DX
    Samsung SyncMaster 220WM
    500GB WD SATA II 500GB Seagate SATA II
    700W OCZ GameXStream
    Cooler Master Centurion 5
    Arctic Cooling Freezer 7 Pro
    Logitech G5
    ~3Mb
