hello to you i install 2 hard drive in my intel badaxe2 975 chipset marvell controller as non raid the marvell bios show me the 2 hard drive but in windows i dont see them enven in the manage what could possible goes wrong?
1 hard drive is with windows vista ultimate sp1 (c: volume)
the other one is (d: volume) few movies
i connected them to the marvell 88SE6145 controller in the marvell bios i see them but when windows vista complete loading up it restart automaticly try safe mode nothing then i connected c: volume to to the ich7 controller everything back to normal but the d: volume stay in marvell recognized in the marvell bios but in windows dont. in the book says
NOTE
The Marvell 88SE6145 controller supports single drive non-RAID configurations as well
as RAID configurations.
NOTE
OK, since I have the same motherboard…
1- Make sure the "secondary" controller is enabled in the BIOS - that's for the Marvell controller.
2- If you did not install the Marvell RAID drivers while installing Windows, (page 93 of the owner's manual) then moving your C-Drive to the controller will cause windows not to boot. The fact that you got it to safe mode was good I suppose, Windows will usually just blue screen.
At any rate you'll need to leave the C-Drive on the Intel controller unless you reinstall the OS with the Marvell RAID drivers on the floppies. - Again, page 93 of the owner's manual.
If you plan on using the Marvell controller for a RAID setup, read at page 91-92.
So why are you attempting to use the Marvell controller? Do you have more than 4 SATA devices, or are you trying to run a RAID setup?
If the answer is no to either, personally I’d leave the Marvell controller alone, especially for RAID, which isn’t all that good and prone to problems, like dropping your RAID setup.
I run 3 hard drives and one SATA DVD writer and just use the Intel controller and disabled the Marvell controller, but that’s me.
Let me know.
ok good guide i understand it i have this bios update file i will update the bios but the hard drive e: and f: volume in my computer are very importent to me i repeat very improtent my question is if the marvell are 100% reliable in non raid mode and works exactly the like the intel controller and yes i know the intel d975xbx2 is retired by intel but remember that the new one x58 smack over (known as so) isent that good 2 pci exprees only 8 sata like we any way thanks for the info but still if you can write guide for the alternative
i told you i do what you say i leave the 1 main drive with windows vista (c: volume) on intel controller and the rest on marvell but the windows dont see them why?
If the drives aren't formatted, then yes, they need to be formatted whether on the Marvell or Intel controllers. If they are, then Vista should see them. If for some odd reason {Vista} can't see them then...
1- Right click Computer,
2- click Manage
3- Click Disk Management - check to see if the drives are formatted and have a drive letter assigned to them, if not format and assign a drive letter, or just assign a drive letter if none is assigned and the drives are formatted.
You lost me there???
However - why is it so important to have your main operating system drive on the Marvell controller?
Since you already have Vista loaded and it works just fine on the Intel controller, why not leave it there instead of reformating the drive to have it run on the Marvell controller.
If all your other drives are just data, they will work just fine on the Marvell controller. If the drives are already formatted all you have to do is connect them to the controller and Vista should see them.
You can arrange the drives in any combination you want, just leave the Vista drive on the Intel controller. I'm not understanding your question.
can i connect my 2 sata dvd drives to the marvell controller?
i try also to connect the other hard drives to marvell controller but windows dont see them (vista sp1 32 bit ultimate) but in the marvell bios i see them could be old bios version also try in manage but windows dont see them what can i do?
thanks for the help
thanks for the help
Yes, you can connect the sata dvd drives to the marvell. Then connect the 4 hard drives to the intel controller.
If they are, then Vista should see them. If for some odd reason can't see them then...
2- click Manage
You've yet to answer this question. If you don't asnswer the questions I can't help you! Are the drives formatted???
2- click Manage
Sir,
I'm afraid I've gone as far as I can go in this thread. I told you to update the BIOS, I told you the SATA DVD drives would work on the Marvell controllers. I even gave you an example. If you don't want to try what I've suggested, then that's on you.
Have a good day and good luck.
my 4 hard drive connect to the intel controller and work perfectly
my 2 sata dvd connect to the blue sata (marvell controller) dont seen in windows do i need to install drivers of marvell to get this dvds on or windows vista should detected them automaticly?
Make sure you have the controllers in the BIOS set the either IDE or AHCI, not RAID!!!
...If for some odd reason {Vista} can't see them {the drives} then...
2- click Manage
As for updating the BIOS, that’s easy on that board since it’s an .exe file, but yes, definitely update the BIOS. You can get the latest (2838) BIOS here – Intel® Desktop Board D975XBX2 BIOS Update [BX97520J.86A]. The one you want to get is this “BX97520J.86A.2838.EB.EXE” download it, click the .exe and follow the instructions.
DO NOT REBOOT OF SHUT OFF THE COMPUTER UNTIL TOLD TO DO SO!!! Once that's done you’re updated.
I thought I provided that answer here...
2- click Manage
yes they are formatted to windows vista (only games and music in them d,e,f volumes) and yes try in manage Disk Management dont see them
by the way my bios version is 2674
if its a 100% problem of bios version i will update but if i update the bios all my config gone or stay?
