Installers for Vista
Hi staybolt,
Macrium uses an .exe - if that helps.
Hope fully, after the repair install - all will be well and you can then switch to one of the other backup apps. - or stay with Macrium - it's very good.
That's odd - I have a Dell disc - it is pretty much a regular Vista install disc ( it has the product key included) Otherwise - all the same options as the MS vista installation media.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Vegaspat ,
Is this not working for you ? :
Click here
x86 is for 32 bit system , and x64 is for 64 bit.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
SIW2,
I think I already tried that, but will give it another shot in case I didn't. I've been all over the Internet and in every BB I can find. Nothing has worked and I am not going to lose what I do have by formating my drive.
This is really the pits.
Since someone said version 4.5 came with SP2 I was going to uninstall and reinstall.
Thanks for helping me. I will let you know if I get it worked out.
SIW2
The Dell disk does have the product key with it. But, when I run the repair it ends with the statement I must reinstall the whole Vista system from scratch. I'll run it again anyway and see what happens.
Dave K.
    Dell XPS 410
    Intel Core 22 Quad core processor Q6600 (2.4Ghz,1066FSB) 8MB
    3GB DDR2 SDRAM at 667Mhz
    256MB NVIDA GeForce 8600GT-DDR3
    X-Fi Soundblaster
    Dell 24" flat
    1280X800
    internal 500GB Serial ATA II Hard drive @7200RPM external 2-250 gig's WD
    Logitech wireless
    Logitech wireless
    DSL
Probably because your installation has a more recent SP than the dell disk.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Yeah disk is probably no SP's at all, I have SP2 on here.
    Dell XPS 410
    X-Fi Soundblaster
    Dell 24" flat
    1280X800
    Logitech wireless
    Logitech wireless
    DSL
Do you have all your data mixed in with Vista like a dog's dinner - or do you have your data on separate partitions?
If you want to back up 650gb - you are looking at 650 minutes and an image of 400gb.
If you do have your HD in several partitions , rather than just one - then post a screenie of the Disk Management window - there will an easier way if you do have separate partitions.
[url=http://www.sevenforums.com/tutorials/9733-how-post-screenshot-seven-forums.html] How to post a screenshot
[/URL]
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
All on one partition. (Unfortunately) That was the way the system came and I never partitioned it.
Dave
    Dell XPS 410
    X-Fi Soundblaster
    Dell 24" flat
    1280X800
    Logitech wireless
    Logitech wireless
    DSL
