Installation with multiple CDs need help
It is just another bcd entry.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Yeah I'm not using bcd. Thanks for the suggestion.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
... or are you asking how to create them?
It prompts to insert the next cd
Yeah I'm interested. Man, thats really cool. How did u do it?
    Windows Vista Ultimate x64
    Intel Core 2 Quad Q6600
    Onboard is enough for now
Split install.wim into max size 320mb chunks. I used wimlib to do the splitting, there are several ways to do it - you could use microsofts dism.
The usual way:
The first cd is bootable and contains the installation media as usual - except sources install.wim is replaced by the first chunk , install.swm.
Second cd - not bootable - contains a folder called sources with install2.swm
Third cd - not bootable - contains a folder called sources with install3.swm
and so on. That uses a lot of cds.
Cheating way:
I cheated to reduce the number of cds by doing this:
CD1
CD1 sources folder contains install.swm instead of install.wim
CD2 only a folder called sources
Which contains only install2.swm AND install3.swm
CD3 contains a folder called sources with install4.swm AND install5.swm
and so on.
If you cheat like I did, it reduces the number of cds needed to 5. You have to pay attention, because after inserting cd 2, it copies install2.swm and install3.swm. So it then asks for cd4, because it knows it needs install4.swm - which it thinks is on cd4. But if you cheated, of course you need to insert cd3.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
That's incredible, thank you for all of this... I will try that. Does this apply for all Vista & 7 editions?
No it isn't. Unlike your post, the others are relevant to the question.
OP posted 3 sentences on April 2 and hasn’t been heard from since, so who can say what parts of this discussion have been relevant to him? But no problem, this is Vista Forums after all.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
I found a link through a third party site. This is not from M$ so I would be cautious.
I found it here: Windows Vista on 5 CDs? What I don't like about that is one disk is mostly wasted yet the first disk has some room compared to 3 of the others. But whatever. It is an alternative if the OP doesn't know how to split them up himself, however he hasn't been back since creating the thread.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Seems to me that Ex_Brit was somehow connected with that website but I could be wrong. There is another thread somewhere concerning the
efficacy of those files and, if I remember correctly, I had download them and looked at them. Can't remember what I found but, when I needed the installation files, I got them from Ex_Brit. At that time, Microsoft hadn't yet cut off the Microsoft Catalog for Vista update downloads. Now, S1W2 has an .iso with all the updates.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Those are ancient, it is vista rtm. Better to do it yourself.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
How can you tell?
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
look at the names x12
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
