Installation Adobe Air
Hello Derek,
I think it might be best to just reinstall. However, it's not really urgent at the moment because my computer is running smoothly. But I only foresee problems in the future with updating and all that. I could use some advice on external memory before I reinstall my computer. Which one would be most convenient? I have 40 gb at the moment and I want my memory to be ''endless''. I would like to thank you very much for your efforts and patience to help me out with my issue.
Kind regards,
Robin
    custom made
    INtel Cors 9TM)2 Quad CPU Q6600 @ 2.40Ghz 2.39 Ghz
    ASUSTeK Computer INC. P5KPL-CM
    4.00 GB
    NVIDIA GeForce 9800 GTX/9800 GTX+
    VIA High Definition Audio
    LG W2452 [Monitor] 24,0"vis
    640,13 Gigabytes Usable Hard Drive Capacity 496,45 Gigabytes Hard Drive Free Space Optiarc DVD RW AD-5200A ATA Device [CD-ROM drive] Generic STORAGE DEVICE USB Device [Hard drive] -- drive 4 Generic STORAGE DEVICE USB Device [Hard drive] -- d
You're Welcome Robin,
I wish we could have figured it out. I agree a reinstall is your best bet when you're ready. By external "memory", I think you mean storage, I really don't know if there is a best, but I bought mine from ebay, A 500GB external, USB, that is probably the most common method for connecting them.
A google search for external hard drive will probably give you a good overveiw of what's available and prices, you would probably get a strong opinion from who ever you ask about which one is best. Mine happens to be an off brand and I've had no problems with it.
I wish you well and hope you get it all sorted out soon and come on back if you have any other quesions, There's plenty of helpful people here.
Derek
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
Derek,
Once again thank you very much. Despite I couldn't be helped with my issue, I found this website and the people in it very reliable and helpful. Keep up the good work!!
Robin
    custom made
    4.00 GB
You're Very Welcome Robin,
Thank you for your kind words, come back anytime.:D
Derek
    Asrock P67 Extreme4
    auria eq2367
