in DEPTH help on how to set up security for linksys WRT54G2 wireless routers security
Re: in DEPTH help on how to set up security for linksys WRT54G2 wireless routers secu
If that is all you have to work with [WEP] then give it a shot and set up the network. It will keep joe blow from piggybacking on your network but that is a bout it.
WEP
an attacker can recover the secret key of the network with an average
consumer laptop in 1-2 hours. More advanced attacks were published in the last years making it possible to recover the secret key of the network in less than 60 seconds.
Source:http://dl.aircrack-ng.org/breakingwepandwpa.pdf
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
We have good nieghbors, and dont live in around alot of homes. In factWhen I search for a network no other ones come up because there to far away. Do you think ill be ok?
    Compaq SR5612f
    AMD Athlon X2 4400
    N-Vidia GeForce 6150 SE
    Compaq W17Q
what do you think?
    Compaq SR5612f
    AMD Athlon X2 4400
    Compaq W17Q
what do you think?
I can guess and tell you that I am sure you will be fine with the neighbors. Even though people can by little "hotspot" scanners for $5, and that they then just drive around looking for networks...
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
would you do it?
    Compaq SR5612f
    AMD Athlon X2 4400
    Compaq W17Q
would you do it?
I think you should just set up the WEP network. it isnt the best, but it will enable you to use a wireless network config.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
whats a wireless network config?
    Compaq SR5612f
    AMD Athlon X2 4400
    Compaq W17Q
your network configured for wireless devices
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
So I follow the steps you gave me in your first post in this thread except with wep?
    Compaq SR5612f
    AMD Athlon X2 4400
    Compaq W17Q
yes
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
also since im turning off broadcasting doesnt thatt mean hackers wont be able to see my network anyway, unless they know myy ssid?
    Compaq SR5612f
    AMD Athlon X2 4400
    Compaq W17Q
it will help.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
