1) Suite yourself. You've been warned about loading Windows before testing settings; my hands are clean should anything go wrong. 2) Be sure. 3) You have 8GB's. That's a lot and you may require a slight bumb in voltage. I'm not saying this is certain, but you may. You'll only find out through thorough testing. 4) Again, Prime95 is useless for you. You have a quad core, Prime only tests 1 core. You need to run two instances of Orthos to test all 4 cores. 5) memtest is a series of tests. Each test is unique. When you run it you will see that it goes through tests 1 through 9 in sequence. If you get an error during tests 1,2,3 or 4, then that tells you that there's an issue with your fsb... perhaps insufficient vcore. If you get errors in tests 5 and above, then that tells you your memory has an issue; either insufficient voltage or incorrect timings.I seem to load to Windows just fine. The bsod happened playing BF2. I think the first bsod was when front side bus was set at auto, I am not sure now. The voltage is 1.9v going to the ram, same as Corsair's rating for the ram. Time to get Orthos. ... The highest temp I have seen while running P95 was 58*C. I also have NVidia System Monitor that log temps and other features that I plan to use instead of Core Temp. "Errors in tests 1-4 are front side bus related; errors in tests 5 and up are memory related." Are you saying here that error #'s 1-4, or tests 1-4? Sorry, I never seen a memtest error before. I will set it from bios to run at startup and test it right now.
I don't know what the nVidia memory tester is. I've never used any of the nVidia tools because they've always proven to be problematic. If I were you I'd uninstall them all.I ran NVidia memory test ( slow ), and I think it checks out ok, because it went right to Windows when it was done.
Fumz, I don't understand what you mean by this, "At the very least, you should set the cas, ras to cas, ras precharge, tras (cycle time) and the command rate.", but I did set the first four to stock (5-5-5-18) and the others to auto. Could auto be the problem, I wonder. Also, memory frequency works out to 799MHz.
How do I snap picture shots of windows, instead of typing what I see?
Memory timings could be a problem, I don't know, you haven't run memtest? Google your RAM and see what other guys with 8GB's run on your board. It may turn out that the auto timings are just fine, then again, you may have to make some adjustments? It's doubtful since you're unlinked and at 800MHz, but it wouldn't hurt to double check.
To take a snapshot inside Windows just hit the PrtScr button on your keyboard and paste it into Paint, then upload the pic somewhere and link it here.
Auto works fine with what, overclocking or stock? johngalt and xguntherx have both OC'd q6600 quads with your board. They can tell you more specifically what voltages to use; however, keep in mind that no two rigs are alike, even if they're made with identical parts. What works for one guy may not work for another, but they can give you a good baseline.Correction, my fsb voltage has to be set to auto, I tried 1.2v, 1.3v, and 1.4v, all with errors, but auto works fine.
Your bios may indeed be a problem. However, before I just went and updated it, I'd find out how well it overclocks? If all they did was add support for 45nm cores, and did nothing else, then there's no point to it.
- Fumz' Flux-Capacitor
- E8400
- DFI LP DK P35-T2RS
- 4GB G.Skill PC-1066
- eVGA 8800 GTS
- X-Fi XtremeGamer
- Samsung 226BW
- 1680x1050
- 500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
- PSU
- PC Power & Cooling Silencer 610
- Case
- Lian Li Lancool K62
- Cooling
- Thermalright Ultima-90/S-Flex 120mm
- Logitech G5
- MS Natural Elite 4000 Ergonomic
- 2.5MB/430
- Other Info
- D-Link DGL 4500
