IE8 Beta1 Launched
Um Where's the File you are Describing it may say Vista at the Top But all Down Loads are from XP2
IE8
Quick Details
Version: 3.0
Date Published: 3/18/2008
Language: English
Download Size: 434.3 MB - 3298.6 MB*
*Download size depends on selected download components.
Overview
A VPC hard disk image containing a pre-activated Windows XP SP2 or Windows Vista, and IE6, IE7 or IE8.
Files in This Download
The links in this section correspond to separate files available in this download. Download the files most appropriate for you.
File Name: File Size
IE6_VPC.EXE
435.1 MB
Download
IE7_VPC.EXE
434.3 MB
Download
IE7-VIS1.exe
700.0 MB
Download
IE7-VIS2.rar
700.0 MB
Download
IE7-VIS3.rar
590.5 MB
Download
IE8_VPC.EXE
438.6 MB
Download
I am running IE 7 at the present time. Tried Firefox a couple of times but didn't care for all the downloads (icons) on my screen. With reguards to IE 7 I have two questions, (1) slow to load, it makes 5 or 6 clicking sounds and it appears. (2) Tune-up Utilities informs me that I have 64 bit but only using 32 and could gain memory by upgrade. Can I increase RAM by using a card or a plug in. I have 270 GB free of 289 GB so its not a space problem. Finale question can not view videos on line with out the constant start and stop for buffing, Same with some of my e mail. Thank you for your help. This forum and it's members are great.
    H P Pavilion s3120n
    AMD Athlon 64X2 Dual Core Processor 4200+ 2.20GHz
    M2Nc51-AR
    Ram 2.0 GB
    NVIDIA GeForce 6150 LE Graphis
    Realtex
    ViewSonic VX2035WM
    1680X1050 pixels
    320GB 7200RPM Serial ATA
    AC Bel Model#PC6012
    fan
    PS2
    PS2
    10 down 1 up
    Computer has had the motherboard, power pak and tv tuner replaced. Using HP Deskjet F440 Printer, and IE9.
