icons flicker
ok, I'll run it on the parents' desktop first, theirs is even worse off performance wise... though theres less to redo if it decides to react badly.
    laptop: hp pavillion dv6-1250us
    intel core 2 duo p7350 @2.0ghz 2.0ghz
    unknown
    4gb
    intel graphics media acellerator
    idt pc audio
    inbuilt laptop screen
    1366x768
    1@500gb
    fios 15/5 lowest level tier.
    browsers: mozilla firefox google chrome
HP Support Forum - HP Support Forum
Note that Vista and Win 7 both automatically defrag your hard drive. The best handy utility is the Windows Disc Cleanup utility in Accessories. Run that and reboot. I recommend that everyone run that periodically. I don't know if it does anything different than the CC Cleaner you've already used.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
thanks chief.
    unknown
    4gb
    idt pc audio
    1366x768
    1@500gb
If you post in the HP forum and get a resolution, please let us know what it is.
I still think it's in the graphics accelerator or it's interaction with the cpu.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
well, if it recurs, I'll go ahead and ask them, but since theres no sign of it happening again *knocks on wood*....
    unknown
    4gb
    idt pc audio
    1366x768
    1@500gb
Technology is great, when it works. :D
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
