i cant download updates! plz help
I ment, plug your computer directly into your modem.
To eliminate the chance your router was missconfigured.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
We can scan for a virus very soon. There is actually one virus which has been known to cause Windows Update issues. Your error codes point to a Windows Update Network issue, but we may as well try the manifest side of things since we have reset everything.
Download and run this tool: Description of the System Update Readiness Tool for Windows Vista, for Windows Server 2008, for Windows 7, and for Windows Server 2008 R2 When it has finished installing the update, it is done!
Copy C:\Windows\Logs\CBS\CheckSUR.log to your Desktop, and then upload it here.
TDSS has been known to cause these issues. Run the TDSS Killer, AND COPY THE LOG HERE: How to remove malware belonging to the family Rootkit.Win32.TDSS (aka Tidserv, TDSServ, Alureon)?
Thanks!
Richard
P.S. It goes without saying that you should remove any threats found my TDSS Killer.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
the website opened normanly and everything, but when i clicked on Downloaded.. it says unable to connect or unable to display webpage!
for the file u want, i didnt find it there ,, there is only -CBS -CBS.persist -FilterList
log is attached!
oh and btw, the updates worked! :) but what i did was:
since the problem was from my Internet connection, i used proxy! so when my IP address changed, the updates where installed successfully :D
but the main problem persists, cause i still can't connect to the windows update without proxy! :confused:
