Huge problem with nvlddmkm
Youre computer also has the dread 8 series video card. They like to get really hot and cause problems. Some even melt the laptop plastic!
I'd goto the hp site and d/l and install the network drivers, use repair if it gives the option
Product search results
And select your model.
Also grab the driver from nvidia: NVIDIA DRIVERS 260.99 WHQL
The driver is just a run program, so it can't be screwed up.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
thanks i will try with the nvidia drivers since i dont know which one to pick on the hp site there is too many and its all the same to me...
    HP Pavilion dv9700 Notebook PC
    Nvidia GeForce 8400M GS
    Synaptics PS/2 Port TouchPad
    Standard 101/102-Key or Microsoft Natural PS/2 with HP QLB
I can tell you if you know your model. My hp had it writen on the keyboard.
