How to ask for help
Status
Not open for further replies.
People being confused also gets them angry, not anyones fault but it is human nature. Give people a little bit of leaway when replying to a post. If someone does start to get a bit harrased tell them to calm down and explain in simpler terms or give them a web link to a written document that will explain things better.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
When you ask for help on vistax64, your CD or DVD drive will open. You must insert $20 if you want an answer. Insert $40 if you want the correct answer. :D
Warning!!
Believing this could be hazardous to your wallet, and DVD drive. ;)
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Warning!!
With that much I might as well buy vista all over again, I mean at 130 dollars right now my pc might upgrade itself. Does it take credit card too?...or where do I add my PIN...Lol
I agree with everything said here...it was a good thing to post this as a sticky for future reference...I even have it bookmarked for other software forums as a reference on how to make a good forum on technical issues.
Keep up the good work!!:D
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
Warning!!
:roflmao:
I love it.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
You could contact one of the moderators for questions concerning the forums :)
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Okay then, here's mine: For a reason beyond me, I cannot send PMs. I've read the FAQs but they haven't been very helpful. I'm sure the reason is simple enough, but I would appreciate it if some one could tell me what it is.
Hi Lord Of Ages,
Try this -
Go to User CP - Your Control Panel - Settings & Options - Edit Options - Messaging & Notification - Private Messaging - Make sure there is a tick in the box " Enable Private Messaging" - Scroll to bottom of page & click "Save Changes."
Let us know how you go.
Good Luck.
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Hi Lord Of Ages,
Try this -
Good Luck.
Alright, I checked and it is enabled, so...?
Hi Lord Of Ages,
Try this -
Good Luck.
I suggest you leave a visitor message for ADMIN at the link below detailing your problem.
http://www.vistax64.com/member.php?u=1
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Hopefully you'll get your issue fixed.
Good luck
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
Hi Lord Of Ages,
Try this -
Good Luck.
You only have a post count of 6. PM's are disabled until you reach a certain count ( possibly 10 IIRC )
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Hi Lord Of Ages,
Try this -
Good Luck.
Thanks Patrick for this info. ;)
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
TY Kind Sir(or Maam-whichever the case may be). I do not consider myself to be a novice, but I don't feel I'm a intermediate either...somewhere in between. Anyway, thank you for posting that cuz I know that it will help me as well as many others.
So again, thank you.
*respectful bow*
    LENOVO 3000 J200 969084U
    INTEL CELERON [email protected] GHZ
    XEROX 17 inch LCD
    800x600
*respectful bow*
You're welcomed :)
and it's Sir :)
Thanks
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
difference between 32 bit and 64 bit
Hi yogeshagrawal, Welcome to Vista x64,
This thread is not the place to answer your question. You'll need to post your question in the appropiate forum (General Forum). Also, you should do a search here as well as Google as this question has been asked and answered thousands of times.
You could take a look at this article to get a sense of what 64-bit is about: http://www.vistax64.com/vista-news/99613-64-bit-more-than-just-ram.html
Thanks and good luck.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
yoo!!, i have a problem. i own a pc which has vista home premium, recently i brought a game dvd (game cd) which works only in vista and xp, my pc does not seem to recognise or read the dvd but perfectly works on my dads laptop which has windows XP. is there something wrong with the software i have? please can any body tell me???? oh! and one more thing, the movie dvd's works on my pc except game dvd's.
Please see the post above yours.
Thanks.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
Status
