How many FPS do YOU get on crysis?
Arrrrggghhh... reading is not one of my strong points :(
Fine, you win... I'll read it ;)
Settings? 1680 x 1050 and everything at High with 8x AA No V-Sync.
if its crysis your playing and not crysis warhead pay particular attention to his "very high on the cheap" section , there is very little differance between the original crysis in DX10 as oppsosed to DX9 visually . you can tweak your cfg file to set Very high setings when in DX9 (all the insructions are there if you really cant be arsed to find our how PM me and ill tell you) the image quality is very close to DX10 but you'll get on average an extra 10-15 fps , just look at his screenshot comparrisons
with crysis warhead the differance between DX9 and DX10 is more pronounced DX10 looks much better
trust me on tis one you MUST read that guide if you like crysis :D
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    Geforce 8800GT 512mb
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech MX Revolution
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
I run Crysis in "Extreme High Quality".
Crytek's Official Modding Portal | Finished | Crysis Extreme Quality [1.34] TOD modification in the works.
I usually get anywhere from 23-40FPS running in 1600x1200.
I am still running an old 8800GT 512mb card.
ill certainly look into that one :) are you running DX10???!!
one thing always worries me about those screenies is its all very well getting 30fps staring into space but when it all kicks off its a differant story , and i cant manage to maintain those framerates your getting with a 260GTX nevermind an 8800gt , ive just upgraded from one of those so i know this card is twice as fast
those tweaks may be good but i can beleive there that good :p
edit after seeing what that mod does all i can think is it'll hit the fps even more!!
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Hi archie and ..., don't know if this has been mentioned already, 190.38 driver really helps. I'll be able to max out on almost all settings except AA off on Warhead. There is no obvious different with AA off with max resolution. Also, the fps on Street Fighter 4 benchmark is almost double!
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
not really i agree but 2AA does reduce shimmering in distant textures i notice @ 1680x1050 , that said i use the edgeAA command to smooth out the foliage , it makes the whole game look better , AA doesnt work with edgeAA enabled though but its a good tradeoff , edge AA has the ............ erm ............edge ;)
i have it running now at 1680x1050 all settings enthusiast DX10 and im getting minimum 20 maximum around 43 , with a few tweaks however in the end battle with the big monster thingy i was seing 15fps at times :p
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Archie, I only play the Campaign and I have done both Crysis & Warhead to death so I am not going to invest to much time on it but, I usually like to tweak here and there just to learn and for fun.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
then look at nunyabiz post and tweak it for eye candy , its pretty bloody impressive , plays havoc with your fps though ;)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Yes I am running DX10.
Just try the mod it doesn't really take much of a hit in FPS.
I rarely get any less than low 20's average probably 28-30 and just cruising around get higher, its playable for me in the single player mode, if I go online I tone it down to get 35+.
The graphics are so good with it that I find myself just strolling around looking at sh!t quite a bit.
    Home Built
    Q6600 @ 2.66ghz
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Cooler Master 750W
yeah me too i just kill all the baddies then go into strength mode and knock everything down ;)
i have tried the mod , well ive added the tweaks to the autoexec i already have it is impressive
could somebody try this
con_restricted=0
sys_budget_videomem = 896 <<<<set to yuor vid mem
r_TexturesStreaming=0
(IF YOUR RUNNING 32BIT I THINK THE TEXTURES STREAMING TWEAK MIGHT CRASH THE GAME SO BEWARE)
in an auto exec , see what you get? i might just be imagining better fps im not sure :p
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
I may just have to try that tweak, I took Wolfenstein for a ride and it was not what I expected. :rolleyes:
I used to love to do that with the Original Far Cry, not so much with Crysis because the water/scenic are not as big as they were in FC but, I will probably go for a stroll after I finish with this tweak of yours :p
archie, I would gladly try your tweak if I understood it or knew where to add that code at. :huh:
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
he he you paste it into notepad and save as autoexec.cfg then save it to yuor game folder in crysis/warhead , but forget it its no use
sys_budget_videomem that bit was because i heard crysis sets all vid ram usage to a max of 256 mb which turns out to be nonsense :p
r_TexturesStreaming=0 that bit caches textures instead of streaming them you need plenty of ram for it and a 64 bit system , it also improves IQ which it does do , im sure it caused a bit of stuttering for me
con_restricted=0 that bit is just to enable the full console so all the tweaks work , all in all afetr testing texturesstreaming does work videomem does nowt ;) forget it ;)
crysis warhead looks good , it doesnt run any better than crysis as it was supposed to and the whole game can be completed in about 2 hours!!
im trying to get into the multiplayer (crysis wars) but its not doing anything for me , at least it only cost me £10 :p
a whole lot of tweaking to get a very short sub par game running nicely.........it hardly seemed worth the effort........
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
I don't have a autoexec.cfg on my Crysis or Warhead games to overwrite so I don't know if just pasting the nunyabis tweak will work.
if I make a new autoexec.cfg and paste it into the Warhead Game folder, would it do what the tweak is supposed to do?
I'll try it anyways but I just want to be sure... sorry if my noobness is showing off here! :o :D
Also, if:
I have 8 GBs of Ram, what should I be setting mine to? 256, 1GBs, 4Gbs???
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
Also, if:
the video mem thing doesnt work its not worth the hassle but you would set it to your video ram so the max of your gpu not your physical ram :)
and yes you create the cfg yourself and put it in the game folder the tweaks are applied automatically at startup of the game , but my tweaks are a bit pointless , after testing they seemed to do nothing , however the texturesstreaming tweak does work and improve IQ
look up the r_texturessreaming tweak here on this page TweakGuides.com - Crysis Warhead Tweak Guide
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Thanks Archie123... I'll try it
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
