ProjectDan35
Good luck. Be careful putting it in and don't use too much thermal compound.
I have 3gb. Max for 32bit vista.
Been doing the same cleaning tasks for years, computer is running top notch. Thanks though!
FYI mathematically 2^32 = 4 gb however Widows 32-bit sometimes has trouble with that much. One consideration is how much your motherboard can handle however 3 gb is more than enough IMO.
Thanks. How much paste do you put on?
- eMachines ET 1161-05
- AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
- 3gb
- Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
- Realtek HD Audio
- Samsung 23" LED, 1920 x 1080 resolution
- 1920x1080
- 160gb Seagate
- PSU
- Cool Master Extreme Power Plus - 500watts
- Case
- APEVIA X-Trooper Case w/ Side Window-Blue
- Cooling
- 4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
- Logitech
- Logitech k800 Wireless Illuminated Keyboard
- 150mbps
- Other Info
- Linksys WUSB100 Insignia 2:1 Sound system.
