Hey thanks for caring mate. Well i initially have an integrated network card onboard(Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller showing up in device manager,actually there are two of them!I guess its because of the 2 network ports). Thing is its a bit funny at times. It takes a long time to appear as connected(blue ball on two televsions in taskbar in vista) although i can start browsing and everything after booting up. Kaspersky Antivirus would only load after it would show in task manager as connected. But luckily windows update corrected the matter with an updated driver. Although the network card is integrated on board the initial driver has PCI-E mentioned in it. Even the one on Asus website on the motherboard drivers is the same but slightly outdated version. That's because network cards were PCI-E before i guess..Now antivirus loads up normally regardless of internet connection showing as active or not.
-Tried all that you said, nothing yet!![]()
Remove any and all USB devices....
Remove any PCI card (Sound, network, etc etc) from your PC... with the exception of your video card. If you have a spare video card you could use, swap it out....
Remove/Disable sound card...
you need to physically remove these things, unless they are integrated into your motherboard...
remove any external hard drives. remove any internal HDD except the one with the OS installed on it....
If the problem persists, run a disk check on that HDD.
check back here.
- Myself
- Intel Core i7 920
- ASUS P6T Deluxe
- 6gb MUSHKIN DDR3 1866
- TWO x EVGA NVidia GTX 285
- Soundblaster Extreme
- ASUS 24inch 2ms LCD
- 1920x1080
- 4 x OCZ Vertex 60GB, 1 x Western Digital Velociraptor 300GB, 1TB Western Digital Caviar Black
- PSU
- Corsair 1000W
- Case
- Coolermaster HAF 932
- Cooling
- Water cooled
- Microsoft Regular USB w/wheel
- Saitek Cyborg Deluxe
- Cable 15mbps
