HIGH Cpu usage.. read most posts..
I realize that, I was talking about the Vista ISO download.
    Wolfdale E8400 3 Ghz
    Asus P5E
    4 x 2GB Corsair
    BFGTech GTX260 OC
    Onboard 5.1 w/ Logitech 5.1 speakers
    19" CRT
    1280 x 1024
    2 x Seagate 250GB SATA RAID 0 (OS), 1 x Seagate 500GB (storage), Kingwin SATA removeable rack (Seagate 400GB for Windows 7)
    BFG Tech 550W
    Antec Nine Hundred
    Stock
    Logitech trackball
    Logitech G15
    6Mbps
Now what do you mean an "unmolested" dvd
I mean an actual, unmodified copy of the Vista DVD, not one hacked or cracked for illegal use.
    Asus P5E
    4 x 2GB Corsair
    BFGTech GTX260 OC
    19" CRT
    1280 x 1024
    BFG Tech 550W
    Antec Nine Hundred
    Stock
    Logitech trackball
    Logitech G15
    6Mbps
Sorry to ask the same question 800 times.. but ok.. break down..
If I find a unmolested Vista ISO DVD with no modifications, I SHOULD be able to format my hard drive and install it, and by using my current key (bottom of my laptop) I can put that in and have a legal version of Vista.. And in theory (extreme theory) this should fix my laptop :-p
Well, as far as fixing your laptop I can't say yes or no as we don't know what's causing the problem, but a clean install without all of HP's bloatware is a good place to start.
    Asus P5E
    4 x 2GB Corsair
    BFGTech GTX260 OC
    19" CRT
    1280 x 1024
    BFG Tech 550W
    Antec Nine Hundred
    Stock
    Logitech trackball
    Logitech G15
    6Mbps
Well I am just going to do a complete reinstall with the bloatware and uninstall all the crap that I dont need :-p, I mean i think its safer in the longrun just in case the cd i get isnt working correctly :/. I will update you guys later on this to tell you if things are working fine :-p
Do the restore, do not remove anything. Use the PC for a bit and see if the problem is gone. If so, remove 1 item at a time and reboot, checking to make sure the problem hasn't returned afterwards, this way you can better isolate the cause if it crops up again.
    Asus P5E
    4 x 2GB Corsair
    BFGTech GTX260 OC
    19" CRT
    1280 x 1024
    BFG Tech 550W
    Antec Nine Hundred
    Stock
    Logitech trackball
    Logitech G15
    6Mbps
Oh ok, I will try this, i will do the factory settings, update the drivers.. get my antivirus on there etc.. and see if it presist. :-p
Any suggestions for free antivirus, adaware, and spyware.. or should i stick with avira, spybot S&D and ad-aware
