HELP
Corn
One day my laptop was open and someone came in and SLAMMED the cover closed, and that messed something up.
It will not start up correctly, if my computer is off, and then turned on, this is what happens:
It starts successfully to the screen where you have to enter the boot password, after you enter the boot password, the following message just keeps being displayed:
For Realtek RTL8111B/8111C gigabit Ethernet Controller v2.06 (070425)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM.
Operating System not found
Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
It just keeps showing that over and over.
I have a "Microsoft Windows Vista Home Premium 32-Bit Operating System Disk" which says "Use this disk to re-install your operating system". If I use this disk will it completely wipe all my old files???
PLEASE HELP, THANK YOU
first try booting into safe mode by hitting F8 repeatedly when rebooting. what happens
try booting from the vista dvd, what happens?
tell us about your computer
tanks
ken
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
I pressed F8 repeatedly and after my boot pass, it said "A disk read error occurred. Press ctrl alt del to restart"
And what's the vista dvd???
Note: the pc runs very slow
Could I use the OS disk and my files still be there???
what does "OS disk" say on the label?
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
****, it syas "Warning: this process erases all data and files from the hard drive"
Im just going to go to best buy and tell em to put my data onto a cd then im throwing this piece of **** out, I'm so mad!
If by "SLAMMED" you mean it was closed in a violently hard manner while it was powered on then my friend your hard drive is probably been defunked and will require you to do a reinstall of windows. The same thing can happen if a power failure occurs in some cases, most of the time a power failure will not yied this result but I just had to reset one up this happened to for a customer.
Try all options listed by the other posters and also check the hard drive to make sure it is properly connected as the "slam" might have jarred it slightly and it might have a slight connection issue. That error is basically telling you it does not see a drive with an operating system on it so re-installing will be your only option if all else fails.
    Amd Athlon X2 6400+ BE
    ASUS Crosshair 590 SLI
    Corsair XMS2 X 4 (8 gigs)
    Nvidia 8800 GTS 512 G92(SLI'd)
    Soundmax
    Samsung Syncmaster 2053BW 20"
    1680X1050
    WD 320, WD 500
    Thermaltake Toughpower 850 watt
    Raidmax Smilodon
    Air cooled,5 case fans
    Logitech MX400
    Microsoft
    16mbps
You can use an Ubuntu live cd to backup your data to an external hard drive. Something might have been loosened or fractured, as has been mentioned. Once you get your data, slam a bat into whoever's face who slammed your laptop lid.
    Sony Vaio Z46GDU
    P9700@2.8GHz w/6MB L2 cache 1066MHz FSB
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
what model is your laptop, I will recon you run a hardware check from the bios to see if there is any hardware damage.. It can be a simple thing that the hard disk had moved or even the cards..
