I have a Windows Vista Studio XPS from Dell (can't remember the exact number)
As I said in an earlier post, when my resolution is 1680x1050, I have only a choice between 60 Hertz and 59 Hertz with 60 Hertz as the default setting.
Yes, but aside from the resolution you are running at (and refresh rates vary depending on what your monitor can handle at that specific resolution as well as the display cable (i.e. Dual-link DVI)) im only wondering what type of CABLE your using to connect your display to your Dell. My screen gets bumped up a bit too if i set the refresh rate to an odd selection for that resolution and i was wondering if it was the same for you.
Still, if this works for you, then thats all that matters.
- JUST ME/Custom Built
- Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
- EVGA NFORCE 790I SLI FTW Digital PWM
- 8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
- 2x GTX 480's w/ Koolance VID-NX480's
- Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
- Acer P243W 24" Premium Series
- 1920 x 1200
- Seagate Barracuda 7200.11 1 TB HDD 32mb cache (3 Platters, 6 Heads model)
- PSU
- Ultra X4 1050W PSU 76A Rated 12V SLI
- Case
- Antec 1200 Full tower ATX case
- Cooling
- x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
- Logitech LX310 2.4Ghz Wireless Laser Mouse
- Logitech LX310 2.4 Ghz Wireless Keyboard
- 32mb Download, 12mb Upload from Comcast
- Other Info
- 300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
