On my start menu, I click on the Document and nothing happens. How can I open it?
Please help.
Thanks
Please help.
Thanks
Hey...Brink!
I know it's off topic but I already asked in the general forum with no success. I thought you would help me out. I click on the Document botton on the start menu and nothing happens. What's wrong? Please help me.
Here is what my start menu looks like:
Admin
Documents(I click on it once) nothing appears.
Pictures
Music
Games
___________
Computer
Network
Connect To
___________
Control Panel
Default Programs
Help and Support
Hello...Brink!This tutorial will help show you how to:
http://www.vistax64.com/tutorials/148532-how-use-snipping-tool-vista.html
I just open the Start menu and press the Ctrl+Alt+PrtScn key. Next, I open up Paint (mspaint.exe) and press Ctrl+V, then save the image somewhere to upload later.
To clarify further...
Ctrl+PrtScn will print screen the active window and anything visible around it... basically anything you see on your screen
whereas, Alt+PrtScn will print screen only the active Window.
