Help with Error 652
Toolman78
Windows is telling me there is a new update to be installed. Microsoft .NET Framework 1.1 SP1. I try to download and install it but it gives me error 652 or something like that. Can anyone please help me with resolving this issue? Thanks in advance.
Tim
:cry:
    Dell Inspiron
    Intel Celeron 2.0 GHz
    Dell
    2 Ghz
    Realtek
    AOC 17" LCD Plasma
    1024 x 768
    ATA 180 GB
    unknown
    desktop
    fan
    3D Optical
    Dell
    8 MBPS
    Don't know, this is a new computer, I just bought it on October 1st. It says Windows Vista Home Edition when it starts. Not sure if it's 32 or 64 bit. How do I check this?
Hello Toolman78,
Welcome to the forums.
'652 or something like that' is no help. Please post the entire error message. You could also try a google search on the error number (652 shows nothing).
To check 32/64 bit go to control panel/system. Should tell you there.
Hope this is helpful.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
It's 32 bit and it says "Error 652" Windows encountered an unknown error
It doesn't give me any more information about this. I've tried to update this about 20 times, even turned off my firewall and virus protection, but it still won't update. I am running Windows Vista Home Basic I believe it says when the machine is booting. It's a Dell Inspiron 520S if that helps at all?
    Dell Inspiron
    Dell
    2 Ghz
    Realtek
    AOC 17" LCD Plasma
    1024 x 768
    ATA 180 GB
    unknown
    desktop
    fan
    3D Optical
    Dell
    8 MBPS
