Solved Help with disabling intergrated graphics
I didn't think drivers could be run in a compatibilty mode as they drive the system... only programs I thought.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
First of all. IT WORKS ON XP. But NOT VISTA!!!!!!! which means im stuck on dx9 with a dx 10 card.
Second: everytime i do a FRESH install of vista and i put the card IN it shows the screen at 640X480 or whatever. BUT even if i DONT install drivers, when i next boot it wont show the screen.
Third: Same thing happenes on windows 7
CHEERS
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
I have a question. Have you gone through the BIOS and seen if theres a "Disable onboard Graphics"
THIS WAY IT"LL FORCE WINDOWS , oops, to use the ati card?
You could also try after the system booted, put the screen on to the onboard card. This'll determine which card the systems outputting too.
Ok... first: theres no option in BIOS.
second: if i take the ati card out and connect monitor cables to onboard then YES. i can see vista. BUT then when i try again to do the card. goes no thurther than the Windows Logo.
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Okay on the bios.
No, sorry you misunderstood, when you have both cards in the machine... You say you can hear windows load. So I was thinking that maybe windows V or 7 is going back to the onboard.
So boot up with both in, and see if the onboard got switched to after it booted. Maybe then try to install the graphics drivers.
Technically, you can use both as dual monitors, so maybe theres a setting in the ati drivers to grab the card as main one.
So my thinking
Ok sorry if i mis understood.
But if i do a fresh install the screen shows one time. EVEN if i dont install drivers the computer messes up after. BUT I DO get a message saying
Standard VGA Graphics Adapter has been installed. does that have anything to do with it???
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Oh and for windows 7 even with the intergrated graphics the whole hard drive hangs at the windows logo for EVERun till i turn off.
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Hmmm, thats definately your cause.... Grrr i'd hate to suggest to disable the onboard via the device manage, as someones did that by accident and is now having this issue right now that they can't even see anything.
I'd save your files somewhere safe, and then try disabling the on board via the device manager... reboot then see if your card comes alive.
Ohhh.. i tried that. *sigh. I like vista cuz the wireless is more faster and has direct x 10 and awesome themes. i have just contacted AMIBIOS but the might take a while knowing manufactures
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
BTW it did not work
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
^I figured it didn't work.......
Could you have a bad pci-e socket? I don't know..... I've never read anyone having this much of an issue with getting the card running...
Hopefullyh someone comes by with help on your code 12.
the funny thing is it works on XP so i dont think its a pci-e slot problem
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
its a bummer cuz i cant play games on the crappy 945 chipset and 950 Graphics Media Accelerator
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
Doh, forgot that.
Fr some reason, your computer is setting the resources to the same ones as your onboard.
I think the issue is Vista and the way it divides up its resources.
This Im not knowedgableon vistas insides.
Sorry.
hey no prob. I tried windows 7. Its different. It halts at a file named ClassPNP.SYS. I have looked on google IM EAGER TO GET THIS SORTED.
Cheers again
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
There should be absolutely no reason why the card shouldn't work. Theres just something we all are missing.
HMmmmm. yes but what..... Im positive thers no option in bios. the onboard drivers reinstall if i disable or uninstall. Right now im using the intergrated and i CAN'T PLAY MY GAMES!!!!!!! AAAAAAAAAHHHHHHHHHHHHHHHHH
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
