Help with BSOD
I would try the MotherBoard manufacturers site for the Realtek driver. You will be able to check the Chipset drivers too while you are there.
As for the HDD diagnostics, look at Speccy and see who makes your HDD, go to their site to download the diagnostic software from there.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thanks a lot it's all fixed now :)
    Hp Pavilion a1730n
    4600+ AMD Athlon 64 X2 Dual Core Processor
    2048MB
    Nvidia GeForce 6150 LE
Give it a good test for a few days, hopefully all will go well, good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
heyyy im backk. it worked fine for exactly one day then ahhhhhhhhh!! idk what i did not do. i shut down windows perfectly last night then turned on my computer and BOOMMM. bsod :(
and of course there are mem dump files either. whaat do i do???!
    Hp Pavilion a1730n
    2048MB
Upload the dump files and we will take a look, np.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
lol no i meant there are NO dump files since it crashed while turning on :(, and not during use.
all i have are the ones taht i initially uploaded.
    Hp Pavilion a1730n
    2048MB
