HELP! vista 32 ataport.SYS error
That, of course is always an option. Most members prefer not to go that route and we suggest taking that approach only when all other possibilities have been exhausted. If you decide to reinstall, however, it will solve your problems.
please do guide me to re install my os again properly..
like how to backup in safe mode etc....
    dell studio xps 16
    ati moblity radeon hd 3670
what do u think ..do u still have hope that my system would come to its normal state without re installing the os ??
    dell studio xps 16
What kind of DVD do you have?
Upgrade or regular?
I can give you an answer to that, but if it were mine and I were in your situation, I would cut my losses back up and reinstall.
I however have a backup of the entire system. After you are up and running Ill show you how to back up everything. You will never have to reinstall again.
Good news my friend, you dont even need that DVD. Dell has a restoration partition. Just follow these instructions and you will be up and running again.
With the DVD or the partition you will lose your stuff. Do you have stuff that you want to save?
How do you access Dell’s recovery partition?
i got a driver that says recovery (D) ..should i still use the dvd or the options in the recovery drive
    dell studio xps 16
will it ask for the windows key if i do the factory settings through the recovery drive
    dell studio xps 16
No, but if you ever do need the key its on the computer somewhere.
What do you have, a lappy?
i tried to do the recovery through recovery drive but an error pops us (it has only an ok button and nothing written in it) ..now i am trying it with the cd
    dell studio xps 16
Just try the CD, I just thought that the other way was easier.
ok i re installed it using cd...what else i could do to prevent further crashing of my system ...
    dell studio xps 16
Did you test it, is it ok now?
