help on how to make stubbs the zombie work plz help!!!
AHA!!!!!!
Ok, right click on the game shortcut, and select "properties" go into the compatibility tab, and select run in whatever Windows it was made for.
That should do it
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Found this on PCWorld.com
List of Games that work on Vista
Stubbs the Zombie (Demo) (32-bit tested)
So I would think the full version would work if the demo did.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
You would think. But not always....
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Crap. I though for sure that would do it.........
I will look into it some more, but I have to work on homework first.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Bit of threat necro here, BUT i know how I managed to get Stubbs to work on my pc.
I had previously tried everything from the normal, admin mode + compatability options, re-installed game + the patch and still getting the whole Stubbs.exe has stopped working error, untill I changed my windows DEP settings and added both Stubbs.exe and OpenALwEAX.exe to list under then "Turn on DEP for all programs except those I select:"
Option, then whe nI tried running Stubbs again fro the shortcut still with Compatability mode + Admin permissions, ir worked first time.
