Help Norton and Kaspersky can't find virus or worm!
If you are going to Kaspersky forum may be run their LiveCD first - if you have not already. Index of /devbuilds/RescueDisk/
Get cdrw ready and try some more, cant hurt to scan.
Bitdefender Index of /rescue_cd
Avira Avira AntiVir Rescue System
Dr. Web Dr.Web LiveCD is a software product that features a standard, Dr.Web scanner
Remember to update before scanning, Aviras cant though.
I saw 1 min of his video on Youtube. Find it hard to believe he is a major risk to someone living in Sweden.
Only thing making sense is you installing same evil/wrong software over and over and mistake that for weirdo attack. But you dont so mystery. Post back if you find out what it is.
Since you have Windows SDK I dont think you need help from programs to find updated drivers.
Should think Kaspersky is enough to cool paranoia and you probably should not install anything else if you have the full suite. But stuff like Comodos free suite is pretty good if fixed on locking things down. Requires interest to use efficiently, dont expect 100% plug&play. Not just Firewall but a thing called Defense+, which might be real benefit of Comodo. Also comes with less than great AV part, can be excluded from install. Check it out but dont install on top of Kaspersky without checking for compatibility, I expect zero if you go by Kaspersky recommendations.
    AMD X2 6000
    Gigabyte GA-MA790FX-DS5
    Corsair 4x1gb 6400C4
    XFX 8800GTS XT 320mb, Generic Nvidia 6200 PCI 128mb
    Onboard Realtek ALC889A
    24" Samsung 245b, 20" Dell 2007WFP, 19" Samsung 193P
    WD Raptor 74gb, Maxtor 300gb, WD Caviar 16SE 500gb
    Corsair 520W
    Cooler Master Centurion 532
    Logitech MX1100R
    Logitech G15
    20mb down, 1mb up
Hi I am no export but it you are using a fully license anti virus try getting in touch with there support as that is what you are paying for. (I am of the belief that some are stated by these people to keep the sales up.)
The truth is out there!!!!!!!!!!
    GATEWAY GM5046b
    AMD ATHLON 64 D/C 4200+
    3GB
    NVIDIA GEFORCE 7300EL (TURBO CACHE? DONT LAUGH)
    REALTEK HD AUDIO
    GATEWAY FPD1975W-UK TFT LCD
    1440X900
    250 GB SATA 2
    SAITEK CYBORG (I LIKE TO WORK IN THE DARK)
    2MB
I'd thought I'd come back to this as it's linked to a sticky file.
After much trouble to find out what was wrong it turns out that I was having trouble with AV. Since this episode occured I have learned that Kaspersky AV does not work properly at scanning certain files. Kaspersky AV scans the files slowly but also uses up all the RAM to pass over the files in effect burning out your RAM memory. The only reason I found this out is because my friend has the same problem.
@PGB1965
You can try all AV Free for a month or so...
P.S After re-reading this Post again I feel I've been a bit of a prat. This happens when I get stressed. So my apologies to everyone concerned with this Post.
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
