hello
i have probleem with my MB , i have 3GB RAM " kingston 800Mhz bus speed "
i try to instal 4 GB "2*2" i have blue screen ! , i try to fix it by update my MB , and i look in intel for the update but i have this error when i run the update :
MB Info :
Motherboard Name Intel Pearl Creek DG31PR
BIOS Version PRG3110H.86A.0059.2008.1024.1834
Maximum Memory Amount 4 GB
CPU : Quad core Q6600
G-CARD: XFX G-Force 8600 gt
i know your Q now , about the Ram ? its the same bus "800mhz" and i test each one alon and its work , but its dosnt work together .
i try to install new windows too , i have blue screen when win setup start !
now the first things i want to know how to fix MB BIOS update probleem ?
then if that will not fix my Ram probleem help me to fix it
thanks for reading my probleem
MB Info :
- core 2 quad Q6600 2400/8m
- Intel dg 31
- 4 GB kingston
- xfx 8600 gt
- LG 19" LCD
- 1280 X 1027
- 1TB seg
- 1M/ps
