Solved Help i lost vista!
Nothing man
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
The best thing is to borrow aM$ installation dvd - do you know anyone who has one ?
Any will do - they all include all Editions of Vista - it is the product key that determines which edition is actually installed from the dvd onto the HD.
If that's not possible, still thinking of a way to make a dvd from what you have.
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
I downloaded the CD from a bittorrent last night. Im gunna try and burn it to a DVD+RW that i got from a store today. I hope that will work.
I have never done a fresh install before so can someone run me through how this is going to work and what i should do for every step?
Thanks a ton guys for the help you all have provided.
Everyone will get rep once we put the SOLVE label up.
Thanks again everyone.
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
    Gigabyte IF233
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
If you're really stuck...I have a dell 530 in the studio...I scrubbed the original O/S to upgrade to a 64bit system...You are more than welcome to have the restore DVD that came with the system.
I'm in the UK ( so it may take a week for so ) but I can post it to you on Monday - if it's not too urgent....In the mean time you can just enjoy the windows 7.
EDIT: hoping you can use a UK recovery disk on a US system.
    system1 (system2)
    q9650 3ghz (i7 920)
    Asus p5q deluxe (p6t deluxe)
    16gb ddr2 (12gb ddr3)
    Nvidia 8800GTS 640mb (285gtx 1gb)
    on board
    Eizo CG301w, Dell 2407
    2560 x 1600 + 1920 x1200
    Raptor 74gb, Raptor 150gb, 500gb x2, 320gb, 750gb (raptor 150gb, 2x 500gb)
    ocz 600w (ocz750w)
    coolermaster stacker (coolermaster 690)
    many fans
    intellimouse
    apple slim aluminum jobbie
    2mb
    Wacom A3 tablet, Epson 3800
Hi Ben,
The offer from Christopher (damocles) might be your best bet. There is plenty of information available on .WIM files, but I haven't manage to locate anything specific yet.
    Gigabyte IF233
Hey guys,
I hate my computer!
The burner wont work!
I have no way to burn a CD so now i am SDFSADFASDFASDF!
AHHHHHHHH what the.
And i dont know anyone who has a Vista CD because all the companies that sent them there computers have a PC RESTORE optition!
WHat do i do!
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Hey guys,
I hate my computer!
AHHHHHHHH what the.
WHat do i do!
There is an easier way-
Do you have an external thumbdrive/usb harddrive big enough to copy the Vista O/S ISO image to?, If so copy it over, then copy this ISO burner to the drive (best that I used so far for burning ISO, and doesnt require installation to run. (like CPU-Z) see attached file.
Take your Drive to the school/public library and burn the iso image to a dvd. Then contact Dell and replace your DVD-RW optical drive under warranty.
For future reference, If your gonna upgrade your O/S, keep in mind that its not covered under warranty, and if you corrupt your restore image/partition and do not have a copy of the external media either buy a OEM system Builder O/S version, or merely state you are trying to reinstal Vista and your partition is corrupted- and Dell will send you the DVD O/S recovery software. Do not tell them you upgraded the O/S as they will shut you down, and decline to support. Leaving you SOL.
Ps- I hope you are running excellent antivirus. MySpace is nortorious for malware.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
thanks rive0108,
I will do that as soon as i can.
Two things.
What are you talking about Myspace?
I never go on there any more
And my support with dell is up. I didnt rebuy the coverage. I guess i should have. O well lessons are learned from bad mistakes. Ill remember this one for a long time!
Thanks everyone and ill let you know how it goes when i get everything squared away!
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Also,
What do i do about the drivers and all that.
I dont how to do those.
Can someone help me with that
I am completely new to installing a new O/S
So help would be great!:D
Thanks guys,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
The offer is still there for the Dell restore disk.
On the whole the install with have most of the drivers you need.
You probably need to update the drivers for your videocard via their website and and other bit's and pieces you have connected ( printers, scanners etc ) again you can find them via their website.
    system1 (system2)
    q9650 3ghz (i7 920)
    on board
    ocz 600w (ocz750w)
    many fans
    intellimouse
    2mb
Enter your model # and download your Dell drivers here, copy them to usb/cd:
Dell Drivers and Downloads
You have SATA hard drives . You will need your SATA/RAID controller driver to reinstall Vista from Disk (Copy driver either to a floppy or usb thumbdrive- It is also possible to slipstream the driver onto the Vista disk, but I think this may be too advanced.)
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
thanks rive0108,
Two things.
Ben
Home Page MySpace.com - __X__ - 21 - Male - Rhode Island - www.myspace.com/neverhavemoney
Ps- you can get a replacement Optical drive from newegg for $20 (get a DVD-RW)
http://www.newegg.com/Store/Category.aspx?Category=10&name=CD-DVD-Burners-Media
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Is it the same person, in myspace that person puts their age as 21 but in a post earlier Ben said he was 16 :confused:
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
Ya i lied in myspace. And i also never go on that. Come on. Not to many people have there real age on myspace. Besides, incase you cant tell, i took EVERYTHING off. I have a girlfriend now and we are going on one year(the beautiful woman with me in the picture. I dont ever use myspace. But we arent here to talk about that.
I am going to get all of the drivers i need from the dell website and put them on my USB and burn them at school.
I did download the Install Files and folders from a bit torrent. Here is what i have (desktop is where everything is)
Can i do anything with this w/o having to burn the files to a DVD?
Thanks again everyone,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Ben
No. The O/S is an iso image (disk image) it has to be burned to a disk. Use the iso burner I attached above to post.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Ben,
If you still have the intact D:\ backup drive, then shut down your computer, and boot into it. I recall from reading something that this is the way to run the program to restore factory default. Its worth a shot. Hope it helps.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Hi Rive,
Now The screenshot has been posted - doesn't look like an iso to me. You may need to turn those files into a bootable .iso before transferring it to usb along with the iso burner , like Rive said.
You can do it easily with vLite.
Ben,
I will post back instructions shortly. PM me when you are back online.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
