HELP... i beg of anyone pls... error 0x80092003
Yes, you did that right.
Download Combofix from any of the links below, and save it to your desktop.<--Important
Link 1
Link 2
Link 3
Click on this link Here to see a list of programs that should be disabled.
The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
If your anti-virus or firewall complains, please allow this script to run as it is not malicious.
Next: Disconnect from the internet. If you are on Cable or DSL, unplug your computer from the modem.
Next: Please disable all onboard security programs (all running with back ground protection) as it may hinder the scanner from working.
This includes Antivirus, Firewall, and any Spyware scanners that run in the background.
  • Double click combofix.exe and follow the prompts.
  • When finished, it will produce a log for you. Post that log and a HiJackthis log in your next reply
Note: Do not mouseclick combofix's window while its running. That may cause it to stall
Please be patient while the scan runs, at times it may appear to stall.
When finished and after reboot (in case it asks to reboot), it should open a log, combofix.txt.
Post this log in your next reply together with a new hijackthislog.
After rebooting ensure your Security applications have been re-enabled.
In your next reply post:
ComboFix.txt
***A guide and tutorial on "How to use Combofix" can be found here:
A guide and tutorial on using ComboFix
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device. One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
ComboFix 10-09-12.04 - Administrator 21/09/2010 5:34.1.2 - x86
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.65.1033.18.3068.1715 [GMT 8:00]
Running from: c:\users\Administrator\Desktop\ComboFix.exe
SP: Anti-spyware *enabled* (Updated) {D25F8255-FCD5-47DC-B7C3-2DEF4C9D3B3F}
SP: Windows Defender *enabled* (Updated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
- REDUCED FUNCTIONALITY MODE -
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
c:\program files\Anti-Spyware\Anti-Spyware.url
c:\program files\Anti-Spyware\DataBase.ref
((((((((((((((((((((((((( Files Created from 2010-08-20 to 2010-09-20 )))))))))))))))))))))))))))))))
2010-09-20 21:37 . 2010-09-20 21:37 -------- d-----w- c:\users\Administrator\AppData\Local\temp
2010-09-20 17:50 . 2010-09-20 17:50 -------- d-----w- c:\users\Administrator\AppData\Local\Threat Expert
2010-09-13 15:17 . 2010-08-30 05:57 767952 ----a-w- c:\windows\BDTSupport.dll
2010-09-13 15:17 . 2010-08-26 01:30 2074 ----a-w- c:\windows\UDB.zip
2010-09-13 15:17 . 2010-08-23 01:36 149456 ----a-w- c:\windows\SGDetectionTool.dll
2010-09-13 15:17 . 2008-11-26 03:08 131 ----a-w- c:\windows\IDB.zip
2010-09-13 15:17 . 2010-09-02 07:00 739280 ----a-w- c:\windows\PCTBDRes.dll
2010-09-13 15:17 . 2010-09-02 07:00 1865680 ----a-w- c:\windows\PCTBDCore.dll
2010-09-13 14:58 . 2010-07-16 06:59 656320 ----a-w- c:\windows\system32\drivers\pctEFA.sys
2010-09-13 14:58 . 2010-07-16 06:59 338880 ----a-w- c:\windows\system32\drivers\pctDS.sys
2010-09-13 14:58 . 2010-09-01 02:13 247824 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2010-09-13 14:58 . 2010-08-28 03:28 102184 ----a-w- c:\windows\system32\drivers\pctwfpfilter.sys
2010-09-13 10:22 . 2010-09-13 10:28 -------- d-----w- c:\users\Administrator\AppData\Local\EnglishHarbourCasino
2010-09-13 09:55 . 2010-09-13 09:55 -------- d-----w- c:\windows\system32\N360_BACKUP
2010-09-13 07:21 . 2010-09-13 07:43 -------- d-----w- c:\users\Administrator\AppData\Roaming\CasinoOnNet
2010-09-13 07:21 . 2010-09-13 07:30 -------- d-----w- c:\program files\CasinoOnNet
2010-09-13 06:28 . 2010-09-13 06:28 1563648 ----a-w- c:\users\Administrator\AppData\Roaming\Notepad++\plugins\config\plugin_install_temp\plugin1\bin\NppFTP.dll
2010-09-13 06:28 . 2010-09-13 06:28 1539584 ----a-w- c:\users\Administrator\AppData\Roaming\Notepad++\plugins\config\plugin_install_temp\plugin1\bin\NppFTPA.dll
2010-09-13 06:26 . 2010-09-13 06:28 -------- d-----w- c:\users\Administrator\AppData\Roaming\Notepad++
2010-09-13 06:26 . 2010-09-13 06:26 -------- d-----w- c:\program files\Notepad++
2010-09-12 19:34 . 2010-09-12 19:34 -------- d-----w- c:\program files\Common Files\PCSuite
2010-09-12 19:34 . 2010-09-12 19:34 -------- d-----w- c:\program files\Common Files\Nokia
2010-09-12 19:33 . 2008-08-26 02:26 18816 ----a-w- c:\windows\system32\drivers\pccsmcfd.sys
2010-09-12 19:18 . 2010-09-12 19:17 36365624 ----a-w- c:\programdata\Installations\{225DB4AA-3CFF-47E8-B3C8-6DAD713E986E}\Nokia_PC_Suite_eng.exe
2010-09-12 19:17 . 2010-09-12 19:17 95232 ----a-w- c:\programdata\Installations\{225DB4AA-3CFF-47E8-B3C8-6DAD713E986E}\Installer\CommonCustomActions\pcswpcsi.exe
2010-09-12 19:17 . 2010-09-12 19:17 61440 ----a-w- c:\programdata\Installations\{225DB4AA-3CFF-47E8-B3C8-6DAD713E986E}\Installer\CommonCustomActions\UninstPCSFEMsi.exe
2010-09-12 19:17 . 2010-09-12 19:17 10240 ----a-w- c:\programdata\Installations\{225DB4AA-3CFF-47E8-B3C8-6DAD713E986E}\Installer\CommonCustomActions\UninstPCS.exe
2010-09-12 19:17 . 2010-09-12 19:17 8192 ----a-w- c:\programdata\Installations\{225DB4AA-3CFF-47E8-B3C8-6DAD713E986E}\Installer\CommonCustomActions\UninstCCD.exe
2010-09-12 18:59 . 2010-09-12 18:59 -------- d-----w- c:\users\Administrator\AppData\Roaming\PC Suite
2010-09-12 18:58 . 2010-09-12 19:46 -------- d-----w- c:\users\Administrator\AppData\Roaming\Nokia
2010-09-12 18:55 . 2010-09-12 18:55 733783 ----a-w- c:\programdata\Installations\{29466F9C-7C6A-419C-B301-F440FAF78760}\Packages\Nokia_PC_Suite\CustomActions\NSU_Inst_fix.exe
2010-09-12 18:55 . 2010-09-12 18:55 8192 ----a-w- c:\programdata\Installations\{29466F9C-7C6A-419C-B301-F440FAF78760}\Installer\CommonCustomActions\UninstCCD.exe
2010-09-12 18:55 . 2010-09-12 18:55 61440 ----a-w- c:\programdata\Installations\{29466F9C-7C6A-419C-B301-F440FAF78760}\Installer\CommonCustomActions\UninstPCSFEMsi.exe
2010-09-12 18:55 . 2010-09-12 18:55 10240 ----a-w- c:\programdata\Installations\{29466F9C-7C6A-419C-B301-F440FAF78760}\Installer\CommonCustomActions\UninstPCS.exe
2010-09-12 18:55 . 2010-09-12 19:17 -------- d-----w- c:\programdata\Installations
2010-09-12 15:30 . 2010-09-12 15:30 -------- d-----w- c:\users\Administrator\AppData\Roaming\MPEG Streamclip
2010-09-12 14:44 . 2007-03-12 15:34 77312 ----a-w- c:\windows\system32\ztvunace26.dll
2010-09-12 14:44 . 2007-03-12 15:34 69632 ----a-w- c:\windows\system32\ztvcabinet.dll
2010-09-12 14:44 . 2007-03-12 15:34 162304 ----a-w- c:\windows\system32\ztvunrar36.dll
2010-09-12 14:43 . 2010-09-12 14:44 -------- d-----w- c:\program files\TUGZip
2010-09-12 13:56 . 2010-09-12 13:56 -------- d-----w- c:\program files\iPod
2010-09-12 13:56 . 2010-09-12 13:57 -------- d-----w- c:\program files\iTunes
2010-09-11 16:04 . 2010-09-11 16:04 -------- d-----w- c:\users\Administrator\AppData\Roaming\Scooter Software
2010-09-11 16:04 . 2010-09-11 16:26 -------- d-----w- c:\program files\Beyond Compare 3
2010-09-11 03:22 . 2010-09-11 03:22 -------- d-----w- c:\program files\Common Files\Java
2010-09-10 16:29 . 2010-09-10 16:29 81016 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\71\1\.cp\lib\S1SLEngineWrapper.dll
2010-09-10 16:29 . 2010-09-10 16:29 101496 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\81\1\.cp\lib\USBFlash.dll
2010-09-10 16:02 . 2010-09-10 16:02 56440 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\73\1\.cp\lib\sef3x1Controller.dll
2010-09-10 15:59 . 2010-09-10 15:59 109688 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\83\1\.cp\lib\WinMobileWrapper.dll
2010-09-10 15:59 . 2010-09-10 15:59 109752 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\67\1\.cp\lib\osds.dll
2010-09-10 15:58 . 2010-09-10 15:58 85176 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\79\1\.cp\lib\UAC.dll
2010-09-10 15:58 . 2010-09-10 15:58 323648 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\10\1\.cp\lib\win32\DIFxAPI.dll
2010-09-10 15:58 . 2010-09-10 15:58 216184 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\69\1\.cp\lib\RegistryReader.dll
2010-09-10 15:58 . 2010-09-10 15:58 158840 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\10\1\.cp\lib\win32\DriverInstaller.exe
2010-09-10 15:58 . 2010-09-10 15:58 154744 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\8\1\.cp\lib\win32\DeviceRemover.exe
2010-09-10 15:58 . 2010-09-10 15:58 117880 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\6\1\.cp\lib\DeviceManager.dll
2010-09-10 15:58 . 2010-09-10 15:58 57344 ----a-w- c:\programdata\Sony Ericsson\SEMC OMSI Module\omsiconf\org.eclipse.osgi\bundles\4\1\.cp\lib\serialio.dll
2010-09-10 04:13 . 2010-09-10 04:13 851968 ----a-w- c:\programdata\MGS\cache\b\biathlonbonus.1867224e07f193acaf7efbba325b104b.dll
2010-09-10 04:11 . 2010-09-10 04:11 2117632 ----a-w- c:\programdata\MGS\cache\a\advancedslots1_gao_sept_2010.a14bcfe0be9a08dacc20f3b3716a56ea.dll
2010-09-10 04:11 . 2010-09-10 04:11 1323008 ----a-w- c:\programdata\MGS\cache\a\advancedslots1xxx_gao_sept_2010.b4ef82cefbff5adee5c54e1665ff11d9.dll
2010-09-10 04:11 . 2010-09-10 04:11 765952 ----a-w- c:\programdata\MGS\cache\t\transition_gao_sept_2010.c5019682c8e08f3f5b171a343182a7a6.dll
2010-09-10 02:31 . 2009-06-10 09:43 88576 ----a-w- c:\windows\system32\tlntsess.exe
2010-09-10 02:31 . 2009-06-10 09:43 71168 ----a-w- c:\windows\system32\telnet.exe
2010-09-09 15:26 . 2010-09-09 15:26 -------- d-----w- c:\users\Administrator\AppData\Roaming\QQMusicUpdate
2010-09-09 15:26 . 2010-09-09 15:26 -------- d-----w- c:\users\Administrator\AppData\Roaming\Tencent
2010-09-09 11:36 . 2010-09-09 14:36 -------- d-----w- c:\users\Administrator\AppData\Local\Sony
2010-09-09 11:35 . 2010-09-09 11:35 -------- d-----w- c:\users\Administrator\Podcasts
2010-09-09 11:35 . 2010-09-09 11:35 -------- d-----w- c:\users\Administrator\AppData\Roaming\Sony
2010-09-09 10:30 . 2010-09-09 10:30 -------- d-----w- c:\users\Administrator\AppData\Local\Sony Corporation
2010-09-08 23:32 . 2010-09-08 23:32 -------- d-----w- c:\program files\7-Zip
2010-09-08 20:34 . 2009-06-12 10:18 26600 ----a-r- c:\windows\system32\drivers\GEARAspiWDM.sys
2010-09-08 20:34 . 2008-01-29 04:32 107368 ----a-r- c:\windows\system32\GEARAspi.dll
2010-09-08 20:25 . 2010-09-08 20:25 -------- d-----w- C:\inetpub
2010-09-08 20:04 . 2010-09-13 14:57 -------- d-----w- c:\program files\Symantec
2010-09-08 15:25 . 2010-09-08 15:30 -------- d-----w- c:\users\Administrator\AppData\Roaming\Auslogics
2010-09-08 14:31 . 2010-09-08 14:31 -------- d-----w- c:\users\Administrator\AppData\Local\TopoGrafix
2010-09-08 14:31 . 2010-09-11 13:55 -------- d-----w- c:\program files\EasyGPS
2010-09-08 12:13 . 2010-09-08 12:13 57344 ----a-w- c:\programdata\DivX\RunAsUser\RUNASUSERPROCESS.dll
2010-09-08 12:12 . 2010-09-08 12:08 185640 ----a-w- c:\programdata\DivX\Setup\finishPlugin.dll
2010-09-08 12:12 . 2010-09-08 12:08 1062184 ----a-w- c:\programdata\DivX\Setup\Resource.dll
2010-09-08 12:12 . 2010-09-08 12:08 850200 ----a-w- c:\programdata\DivX\Setup\DivXSetup.exe
2010-09-08 12:12 . 2010-09-08 12:12 56765 ----a-w- c:\programdata\DivX\DivXPlusShortcuts\Uninstaller.exe
2010-09-08 12:11 . 2010-09-08 12:12 56997 ----a-w- c:\programdata\DivX\WebPlayer\Uninstaller.exe
2010-09-08 12:11 . 2010-09-08 12:11 53600 ----a-w- c:\programdata\DivX\Update\Uninstaller.exe
2010-09-08 12:11 . 2010-09-08 12:11 57691 ----a-w- c:\programdata\DivX\Player\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 18:08 -------- d-----w- c:\users\Administrator\AppData\Roaming\DivX
2010-09-08 12:10 . 2010-09-08 12:10 84063 ----a-w- c:\programdata\DivX\TransferWizard\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 57054 ----a-w- c:\programdata\DivX\DSDesktopComponents\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 54166 ----a-w- c:\programdata\DivX\DSAVCDecoder\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 57532 ----a-w- c:\programdata\DivX\DSASPDecoder\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 56458 ----a-w- c:\programdata\DivX\DivXDecoderShortcut\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 54174 ----a-w- c:\programdata\DivX\DSAACDecoder\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 54153 ----a-w- c:\programdata\DivX\DFXPlugin\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 54128 ----a-w- c:\programdata\DivX\Converter\Uninstaller.exe
2010-09-08 12:10 . 2010-09-08 12:10 54644 ----a-w- c:\programdata\DivX\TranscodeEngine\Uninstaller.exe
2010-09-08 12:09 . 2010-09-08 12:09 54101 ----a-w- c:\programdata\DivX\MPEG2Plugin\Uninstaller.exe
2010-09-08 12:09 . 2010-09-08 12:09 57409 ----a-w- c:\programdata\DivX\ControlPanel\Uninstaller.exe
2010-09-08 12:09 . 2010-09-08 12:09 52963 ----a-w- c:\programdata\DivX\MSVC80CRTRedist\Uninstaller.exe
2010-09-08 12:09 . 2010-09-08 12:09 54073 ----a-w- c:\programdata\DivX\Qt4.5\Uninstaller.exe
2010-09-08 12:09 . 2010-09-08 12:09 -------- d-----w- c:\program files\Common Files\DivX Shared
2010-09-08 12:09 . 2010-09-08 12:09 56969 ----a-w- c:\programdata\DivX\ASPEncoder\Uninstaller.exe
2010-09-08 12:08 . 2010-09-08 12:12 -------- d-----w- c:\program files\DivX
2010-09-08 12:08 . 2010-09-09 18:24 144696 ----a-w- c:\programdata\DivX\RunAsUser\RUNASUSERPROCESS.exe
2010-09-08 12:08 . 2010-09-08 12:12 -------- d-----w- c:\programdata\DivX
2010-09-08 12:05 . 2010-09-11 13:55 -------- d-----w- c:\program files\Smith Micro
2010-09-08 09:57 . 2010-09-08 09:57 -------- d-----w- c:\programdata\ParetoLogic
2010-09-08 09:57 . 2010-09-08 09:57 -------- d-----w- c:\program files\Common Files\ParetoLogic
2010-09-08 09:57 . 2010-09-08 09:57 -------- d-----w- c:\program files\ParetoLogic
2010-09-08 09:11 . 2010-09-08 09:11 -------- d-----w- c:\program files\Uniblue
2010-09-08 08:47 . 2010-09-08 08:47 -------- d-----w- c:\program files\Data Rescue PC 3
2010-09-05 07:37 . 2010-09-05 07:37 -------- d-----w- c:\users\Administrator\AppData\Roaming\Malwarebytes
2010-09-05 07:36 . 2010-09-05 07:36 -------- d-----w- c:\programdata\Malwarebytes
2010-09-03 06:38 . 2010-09-03 06:38 1019904 ----a-w- c:\programdata\MGS\cache\s\simplepickuntilbonus_gao_sept_2010.6cac7171bd4af7dccbfa536b185365c5.dll
2010-09-03 06:38 . 2010-09-03 06:38 1323008 ----a-w- c:\programdata\MGS\cache\a\advancedslots1xxx_gao_sept_2010.9fd0f3becbeef11fbd18f922c2415d4e.dll
2010-09-03 06:38 . 2010-09-03 06:38 2113536 ----a-w- c:\programdata\MGS\cache\a\advancedslots1_gao_sept_2010.bff514082b50d7a815e2a21aacd9736e.dll
2010-09-03 06:37 . 2010-09-03 06:37 1933312 ----a-w- c:\programdata\MGS\cache\s\simplepickxofybonus_gao_sept_2010.fcc526c9467e81ccb387fd5cfdc704a2.dll
2010-09-03 06:29 . 2010-09-03 06:29 1798144 ----a-w- c:\programdata\MGS\cache\c\complexpickxofybonus_gao_sept_2010.10749ccbe15cd8c682312d5d228e059e.dll
2010-09-03 06:28 . 2010-09-03 06:28 765952 ----a-w- c:\programdata\MGS\cache\t\transition_gao_sept_2010.1922b5af032b5756b5d14b9df35203cf.dll
2010-09-03 06:17 . 2010-09-03 06:17 1318912 ----a-w- c:\programdata\MGS\cache\a\advancedslots1xxx_gao_may_2010_ts2.9ab5bb140595bba8fd13b83b24083d91.dll
2010-09-03 06:17 . 2010-09-03 06:17 1273856 ----a-w- c:\programdata\MGS\cache\p\progressivepickxofybonus_gao_may_2010_ts2.f4e34337c173dd0414d8f4ce6301c5e1.dll
2010-09-03 06:16 . 2010-09-03 06:16 2023424 ----a-w- c:\programdata\MGS\cache\a\advancedslots1_gao_may_2010_ts2.f449c9d999de976113be9b55d69527ea.dll
2010-09-03 06:16 . 2010-09-03 06:16 761856 ----a-w- c:\programdata\MGS\cache\t\transition_gao_may_2010_ts2.c7b3419015c96c5796347014e1a92974.dll
2010-09-03 05:57 . 2010-09-03 05:57 106496 ----a-w- c:\programdata\MGS\cache\a\aurora.4a5fa118e253af82dc18a442da7d696d.dll
2010-09-03 05:53 . 2010-09-03 05:53 65536 ----a-w- c:\programdata\MGS\cache\v\void.c19b3dfc09b07295326d40aca47e2109.dll
2010-09-03 05:52 . 2010-09-03 05:52 94208 ----a-w- c:\programdata\MGS\cache\l\lua51host.1b8962f1114286ac91f3ce67ee9654e7.dll
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2010-09-20 21:32 . 2008-12-05 01:03 225871 ----a-w- c:\programdata\nvModes.dat
2010-09-20 20:55 . 2010-09-13 14:58 -------- d-----w- c:\program files\PC Tools Security
2010-09-20 17:26 . 2010-05-23 11:54 -------- d-----w- c:\program files\Norton 360
2010-09-20 17:26 . 2010-05-03 01:41 -------- d-----w- c:\programdata\Norton
2010-09-13 15:17 . 2010-09-13 14:53 -------- d-----w- c:\program files\Common Files\PC Tools
2010-09-13 14:59 . 2010-09-13 14:58 2141292 ----a-w- c:\windows\system32\drivers\Cat.DB
2010-09-13 14:58 . 2010-09-13 14:14 -------- d-----w- c:\programdata\PC Tools
2010-09-13 14:58 . 2010-05-03 01:41 -------- d-----w- c:\program files\NortonInstaller
2010-09-13 14:58 . 2010-09-13 14:58 -------- d-----w- c:\users\Administrator\AppData\Roaming\PC Tools
2010-09-13 14:57 . 2009-04-24 11:41 -------- d-----w- c:\program files\Common Files\Symantec Shared
2010-09-13 14:53 . 2010-09-13 14:53 -------- d-----w- c:\program files\PC Tools Registry Tool
2010-09-13 14:19 . 2010-09-13 14:14 76704968 ----a-w- c:\programdata\PC Tools\DownloadManager\Spyware Doctor with AntiVirus8.0\sdasetup_dl.exe
2010-09-13 10:34 . 2008-12-05 01:26 -------- d--h--w- c:\program files\InstallShield Installation Information
2010-09-13 09:56 . 2008-12-05 00:15 2140 ----a-w- c:\windows\bthservsdp.dat
2010-09-13 09:15 . 2010-04-27 05:12 110200 ----a-w- c:\windows\system32\GDIPFONTCACHEV1.DAT
2010-09-13 06:26 . 2010-08-11 21:05 -------- d-----w- c:\programdata\FileCure
2010-09-12 19:33 . 2009-06-29 18:10 -------- d-----w- c:\program files\DIFX
2010-09-12 19:33 . 2009-08-22 07:00 -------- d-----w- c:\program files\PC Connectivity Solution
2010-09-12 13:57 . 2010-04-27 05:13 -------- d-----w- c:\users\Administrator\AppData\Roaming\Apple Computer
2010-09-12 13:53 . 2009-04-24 12:00 -------- d-----w- c:\program files\Bonjour
2010-09-11 13:58 . 2010-04-30 12:50 -------- d-----w- c:\program files\TuneUp Utilities 2010
2010-09-11 13:57 . 2008-12-05 01:27 -------- d-----w- c:\program files\Dolby
2010-09-11 13:56 . 2010-08-11 22:19 -------- d-----w- c:\program files\IObit
2010-09-11 13:04 . 2010-08-10 18:54 -------- d-----w- c:\program files\Opera
2010-09-11 12:22 . 2008-12-05 03:22 -------- d-----w- c:\program files\Common Files\Sony Shared
2010-09-11 03:21 . 2010-06-30 22:04 423656 ----a-w- c:\windows\system32\deployJava1.dll
2010-09-10 15:56 . 2010-03-11 05:01 -------- d-----w- c:\program files\Common Files\Sony Ericsson
2010-09-10 15:56 . 2010-01-21 04:56 -------- d-----w- c:\program files\Sony Ericsson
2010-09-10 15:56 . 2010-01-21 05:29 -------- d-----w- c:\programdata\Sony Ericsson
2010-09-09 18:21 . 2007-01-13 06:41 -------- d-----w- c:\program files\ArcSoft
2010-09-09 17:36 . 2010-08-11 22:36 -------- d-----w- c:\users\Administrator\AppData\Roaming\CBS Interactive
2010-09-09 16:41 . 2008-12-05 03:25 -------- d-----w- c:\program files\Sony
2010-09-09 14:35 . 2010-04-27 05:10 -------- d-----w- c:\users\Administrator\AppData\Roaming\Sony Corporation
2010-09-08 22:57 . 2009-04-24 11:42 -------- d-----w- c:\programdata\Symantec
2010-09-08 20:32 . 2010-05-03 01:41 -------- d-----w- c:\programdata\NortonInstaller
2010-09-08 19:27 . 2008-12-05 03:25 -------- d-----w- c:\programdata\Sony Corporation
2010-09-08 16:27 . 2008-12-05 01:26 319488 ----a-w- c:\windows\HideWin.exe
2010-09-08 12:42 . 2010-08-11 21:35 -------- d-----w- c:\users\Administrator\AppData\Roaming\Uniblue
2010-09-08 12:12 . 2009-04-25 07:06 -------- d-----w- c:\program files\Google
2010-09-08 11:51 . 2009-05-06 05:16 -------- d--h--w- c:\programdata\ArcSoft
2010-09-07 23:57 . 2010-08-11 22:50 -------- d-----w- c:\users\Administrator\AppData\Roaming\ArcSoft
2010-09-03 09:59 . 2010-08-12 00:20 -------- d-----w- c:\users\Administrator\AppData\Roaming\Skype
2010-09-03 06:52 . 2007-01-13 06:20 -------- d-----w- c:\programdata\Microsoft Help
2010-09-03 03:28 . 2010-09-13 14:58 87400 ----a-w- c:\windows\system32\drivers\pctNdis-PacketFilter.sys
2010-09-02 21:04 . 2010-09-02 21:04 0 ---ha-w- c:\windows\system32\drivers\Msft_User_WpdRapi_01_00_00.Wdf
2010-09-02 18:47 . 2010-06-28 15:52 -------- d-----w- c:\program files\Microsoft Silverlight
2010-09-02 17:12 . 2007-01-13 06:57 -------- d-----w- c:\program files\Windows Live
2010-08-30 14:02 . 2010-08-09 22:25 110200 ----a-w- c:\users\Melancholy\AppData\Local\GDIPFONTCACHEV1.DAT
2010-08-30 12:31 . 2009-12-29 17:18 -------- d-----w- c:\programdata\Messenger Plus!
2010-08-27 02:13 . 2010-09-13 14:53 159296 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2010-08-27 01:13 . 2010-05-28 16:49 -------- d-----w- c:\program files\Mobile Broadband Modem
2010-08-27 01:06 . 2010-05-03 16:33 -------- d-----w- c:\program files\Yahoo!
2010-08-27 00:26 . 2010-09-13 14:58 70536 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2010-08-27 00:26 . 2010-09-13 14:58 123968 ----a-w- c:\windows\system32\drivers\pctplfw.sys
2010-08-26 18:28 . 2010-08-12 03:54 -------- d-----w- c:\users\Administrator\AppData\Roaming\COWON
2010-08-24 07:33 . 2009-09-26 13:12 -------- d-----w- c:\programdata\Apple Computer
2010-08-18 05:51 . 2010-09-13 14:53 237632 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2010-08-15 08:24 . 2010-08-12 00:15 -------- d-----w- c:\program files\PhotoScape
2010-08-15 07:29 . 2010-08-12 02:37 -------- d-----w- c:\users\Melancholy\AppData\Roaming\ArcSoft
2010-08-15 06:18 . 2010-08-01 12:21 -------- d-----w- c:\program files\DSHappyBox
2010-08-14 09:41 . 2010-08-14 09:41 -------- d-----w- c:\programdata\Intel
2010-08-14 09:40 . 2010-08-14 09:39 -------- d-----w- c:\program files\Cisco
2010-08-14 09:39 . 2010-08-14 09:39 -------- d-----w- c:\program files\Common Files\Intel
2010-08-14 08:43 . 2010-08-14 08:43 -------- d-----w- c:\program files\SystemRequirementsLab
2010-08-14 08:37 . 2010-08-14 08:37 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\Yahoo!
2010-08-14 08:37 . 2010-08-14 08:37 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\ArcSoft
2010-08-12 19:26 . 2010-05-03 13:29 30528 ----a-w- c:\windows\system32\TURegOpt.exe
2010-08-12 18:29 . 2010-08-12 18:29 2772992 ----a-w- c:\windows\system32\GPhotos.scr
2010-08-12 13:23 . 2007-01-13 06:41 -------- d-----w- c:\program files\Common Files\ArcSoft
2010-08-12 08:37 . 2010-06-28 16:39 -------- d-----w- c:\programdata\Kaspersky Lab
2010-08-12 08:37 . 2010-05-06 11:35 -------- d-----w- c:\programdata\TSLOG
2010-08-12 08:33 . 2010-08-11 22:19 -------- d-----w- c:\users\Administrator\AppData\Roaming\IObit
2010-08-12 08:21 . 2010-08-12 08:21 -------- d-----w- c:\programdata\IObit
2010-08-12 06:40 . 2009-04-24 14:31 -------- d-----w- c:\program files\Microsoft
2010-08-12 04:07 . 2008-06-16 20:55 126448 ------w- c:\windows\system32\pxinsi64.exe
2010-08-12 04:07 . 2008-06-16 11:00 45648 ------w- c:\windows\system32\drivers\pxhelp20.sys
2010-08-12 04:07 . 2007-01-13 06:24 133616 ------w- c:\windows\system32\pxafs.dll
2010-08-12 03:40 . 2010-05-03 16:37 -------- d-----w- c:\users\Administrator\AppData\Roaming\Yahoo!
2010-08-12 03:38 . 2010-08-11 20:57 -------- d-----w- c:\users\Administrator\AppData\Roaming\FreeFileViewer
2010-08-12 03:36 . 2010-08-12 03:36 -------- d-----w- c:\users\Melancholy\AppData\Roaming\PhotoScape
2010-08-12 03:26 . 2010-04-27 10:24 -------- d-----r- c:\program files\Skype
2010-08-12 02:33 . 2010-08-11 22:36 -------- d-----w- c:\users\Administrator\AppData\Roaming\OpenCandy
2010-08-12 00:46 . 2010-08-12 00:26 -------- d-----w- c:\users\Administrator\AppData\Roaming\PhotoScape
2010-08-12 00:28 . 2010-08-12 00:28 -------- d-----w- c:\program files\SKYPE Recorder9
2010-08-12 00:27 . 2010-08-12 00:27 56 ---ha-w- c:\windows\system32\ezsidmv.dat
2010-08-12 00:27 . 2010-08-12 00:27 -------- d-----w- c:\users\Administrator\AppData\Roaming\skypePM
2010-08-12 00:18 . 2010-08-12 00:18 -------- d-----w- c:\programdata\FreeRIP
2010-08-11 23:56 . 2010-08-11 23:56 -------- d-----w- c:\users\Administrator\AppData\Roaming\PhotoFiltre
2010-08-11 22:50 . 2010-07-25 12:33 -------- d-----w- c:\program files\Common Files\Adobe AIR
2010-08-11 22:49 . 2010-07-25 12:33 53632 ----a-w- c:\users\Default\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller\airappinstaller.exe
2010-08-11 22:36 . 2010-08-11 22:36 333048 ----a-w- c:\users\Administrator\AppData\Roaming\OpenCandy\DLMgr_3_1.6.63.exe
2010-08-11 22:31 . 2010-04-30 12:41 -------- d-----w- c:\program files\CCleaner
2010-08-11 22:05 . 2010-08-11 22:05 -------- d-----w- c:\users\Administrator\AppData\Roaming\Registry Mechanic
2010-08-11 12:15 . 2007-01-13 06:41 -------- d-----w- c:\programdata\McAfee
2010-08-11 11:57 . 2010-08-11 11:57 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\McAfee
2010-08-11 11:57 . 2010-07-25 16:04 -------- d-----w- c:\program files\McAfee Security Scan
2010-08-11 11:49 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2010-08-10 22:02 . 2007-01-13 06:22 -------- d-----w- c:\program files\Microsoft Works
2010-08-10 22:02 . 2010-04-27 10:24 -------- d-----w- c:\program files\Common Files\Skype
2010-08-10 20:18 . 2010-08-10 19:59 -------- d-----w- c:\users\Melancholy\AppData\Roaming\VTExtra
2009-05-04 05:14 . 2010-05-06 10:58 36864 ----a-w- c:\program files\mozilla firefox\components\NsThunderLoader.dll
2010-04-09 06:55 . 2010-05-06 10:58 79664 ----a-w- c:\program files\mozilla firefox\components\ThunderComponent.dll
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2008-01-21 1008184]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2008-08-19 1348904]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-11-05 13556256]
"IntelliPoint"="c:\program files\Microsoft IntelliPoint\ipoint.exe" [2009-11-11 1468256]
"Norton Online Backup"="c:\program files\Symantec\Norton Online Backup\NOBuClient.exe" [2010-06-08 968536]
"PCTools FGuard"="c:\program files\PC Tools Security\BDT\FGuard.exe" [2010-09-02 108496]
c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\
Bluetooth.lnk - c:\program files\WIDCOMM\Bluetooth Software\BTTray.exe [2008-10-15 776744]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"EnableLUA"= 0 (0x0)
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\system]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\VESWinlogon]
2008-11-06 02:32 98304 ----a-w- c:\windows\System32\VESWinlogon.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Wdf01000.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinDefend]
@="Service"
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\run-]
"Messenger (Yahoo!)"="c:\progra~1\Yahoo!\Messenger\YahooMessenger.exe" -quiet
"msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" /background
"WMPNSCFG"=c:\program files\Windows Media Player\WMPNSCFG.exe
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run-]
"NvMediaCenter"=RUNDLL32.EXE c:\windows\system32\NvMcTray.dll,NvTaskbarInit
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe"
"MobileConnect"=%programfiles%\Vodafone\Vodafone Mobile Connect\Bin\MobileConnect.exe /silent
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
"ArcSoft Connection Service"=c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" -atboottime
"DivXUpdate"="c:\program files\DivX\DivX Update\DivXUpdate.exe" /CHECKNOW
"CTRegRun"=c:\windows\CTRegRun.EXE
"GrooveMonitor"="c:\program files\Microsoft Office\Office12\GrooveMonitor.exe"
"ApMain"=c:\program files\AlpsPoint\ApMain.exe
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe"
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring]
"DisableMonitoring"=dword:00000001
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecAntiVirus]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
R1 hname;hname;c:\windows\system32\hname.SYS [x]
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2010-08-12 135664]
R2 OMSI download service;Sony Ericsson OMSI download service;c:\program files\Sony Ericsson\Sony Ericsson PC Suite\SupServ.exe [2009-04-30 90112]
R2 TuneUp.UtilitiesSvc;TuneUp Utilities Service;c:\program files\TuneUp Utilities 2010\TuneUpUtilitiesService32.exe [2010-08-12 1051968]
R3 AdobeActiveFileMonitor7.0;Adobe Active File Monitor V7;c:\program files\Adobe\Photoshop Elements 7.0\PhotoshopElementsFileAgent.exe [2008-09-16 169312]
R3 ApPS2;Alps StickPointer for VAIO;c:\windows\system32\DRIVERS\ApPS2.sys [2009-02-12 67120]
R3 cpudrv;cpudrv;c:\program files\SystemRequirementsLab\cpudrv.sys [2009-12-18 11336]
R3 ewusbnet;HUAWEI USB-NDIS miniport;c:\windows\system32\DRIVERS\ewusbnet.sys [2009-02-17 112128]
R3 ggflt;SEMC USB Flash Driver Filter;c:\windows\system32\DRIVERS\ggflt.sys [2010-01-21 13224]
R3 hwusbfake;Huawei DataCard USB Fake;c:\windows\system32\DRIVERS\ewusbfake.sys [2008-12-30 103040]
R3 massfilter;ZTE Mass Storage Filter Driver;c:\windows\system32\DRIVERS\massfilter.sys [2008-11-12 7680]
R3 MatSvc;Microsoft Automated Troubleshooting Service;c:\program files\Microsoft Fix it Center\Matsvc.exe [2010-04-10 266544]
R3 McComponentHostService;McAfee Security Scan Component Host Service;c:\program files\McAfee Security Scan\2.0.181\McCHSvc.exe [2010-01-15 227232]
R3 nmwcdnsu;Nokia USB Flashing Phone Parent;c:\windows\system32\drivers\nmwcdnsu.sys [2010-02-26 137344]
R3 s0016bus;Sony Ericsson Device 0016 driver (WDM);c:\windows\system32\DRIVERS\s0016bus.sys [2008-05-16 89256]
R3 s0016mdfl;Sony Ericsson Device 0016 USB WMC Modem Filter;c:\windows\system32\DRIVERS\s0016mdfl.sys [2008-05-16 15016]
R3 s0016mdm;Sony Ericsson Device 0016 USB WMC Modem Driver;c:\windows\system32\DRIVERS\s0016mdm.sys [2008-05-16 120744]
R3 s0016mgmt;Sony Ericsson Device 0016 USB WMC Device Management Drivers (WDM);c:\windows\system32\DRIVERS\s0016mgmt.sys [2008-05-16 114216]
R3 s0016nd5;Sony Ericsson Device 0016 USB Ethernet Emulation SEMC0016 (NDIS);c:\windows\system32\DRIVERS\s0016nd5.sys [2008-05-16 25512]
R3 s0016obex;Sony Ericsson Device 0016 USB WMC OBEX Interface;c:\windows\system32\DRIVERS\s0016obex.sys [2008-05-16 110632]
R3 s0016unic;Sony Ericsson Device 0016 USB Ethernet Emulation SEMC0016 (WDM);c:\windows\system32\DRIVERS\s0016unic.sys [2008-05-16 115752]
R3 s1018bus;Sony Ericsson Device 1018 driver (WDM);c:\windows\system32\DRIVERS\s1018bus.sys [2008-06-04 90408]
R3 s1018mdfl;Sony Ericsson Device 1018 USB WMC Modem Filter;c:\windows\system32\DRIVERS\s1018mdfl.sys [2008-06-04 15016]
R3 s1018mdm;Sony Ericsson Device 1018 USB WMC Modem Driver;c:\windows\system32\DRIVERS\s1018mdm.sys [2008-06-04 122024]
R3 s1018mgmt;Sony Ericsson Device 1018 USB WMC Device Management Drivers (WDM);c:\windows\system32\DRIVERS\s1018mgmt.sys [2008-06-04 115368]
R3 s1018nd5;Sony Ericsson Device 1018 USB Ethernet Emulation (NDIS);c:\windows\system32\DRIVERS\s1018nd5.sys [2008-06-04 25768]
R3 s1018obex;Sony Ericsson Device 1018 USB WMC OBEX Interface;c:\windows\system32\DRIVERS\s1018obex.sys [2008-06-04 111784]
R3 s1018unic;Sony Ericsson Device 1018 USB Ethernet Emulation (WDM);c:\windows\system32\DRIVERS\s1018unic.sys [2008-06-04 117544]
R3 sdAuxService;PC Tools Auxiliary Service;c:\program files\PC Tools Security\pctsAuxs.exe [2010-03-15 366840]
R3 VcmXmlIfHelper;VAIO Content Metadata XML Interface; [x]
R3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [2010-03-18 753504]
R3 ZTEusbnet;ZTE USB-NDIS miniport;c:\windows\system32\DRIVERS\ZTEusbnet.sys [2008-11-12 110080]
R3 ZTEusbvoice;ZTE VoUSB Port;c:\windows\system32\DRIVERS\ZTEusbvoice.sys [2008-11-12 104960]
S0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [2010-08-18 237632]
S0 pctDS;PC Tools Data Store;c:\windows\system32\drivers\pctDS.sys [2010-07-16 338880]
S0 pctEFA;PC Tools Extended File Attributes;c:\windows\system32\drivers\pctEFA.sys [2010-07-16 656320]
S1 ElRawDisk;ElRawDisk;c:\windows\system32\drivers\dddsk.sys [2009-02-12 22312]
S2 atashost;WebEx Service Host for Support Center;c:\windows\system32\atashost.exe [2009-03-06 20376]
S2 Browser Defender Update Service;Browser Defender Update Service;c:\program files\PC Tools Security\BDT\BDTUpdateService.exe [2010-09-02 235472]
S2 EmmaDevMgmtSvc;Emma Device Management;c:\program files\Common Files\Sony Ericsson\Emma Core\Services\EmmaDeviceMgmt.exe [2010-08-24 306296]
S2 EmmaUpdMgmtSvc;Emma Update Management;c:\program files\Common Files\Sony Ericsson\Emma Core\Services\EmmaUpdateMgmt.exe [2010-08-24 162936]
S2 FsUsbExService;FsUsbExService;c:\windows\system32\FsUsbExService.Exe [2009-04-07 233472]
S2 iprip;RIP Listener;c:\windows\System32\svchost.exe [2008-01-21 21504]
S2 NOBU;Norton Online Backup;c:\program files\Symantec\Norton Online Backup\NOBuAgent.exe SERVICE [x]
S2 NSUService;NSUService;c:\program files\Sony\Network Utility\NSUService.exe [2008-12-05 303104]
S2 regi;regi;c:\windows\system32\drivers\regi.sys [2007-04-18 11032]
S2 SampleCollector;Intel(R) Sample Collector;c:\program files\Sony\VAIO Care\collsvc.exe [2009-09-16 122880]
S2 SOHCImp;VAIO Media plus Content Importer;c:\program files\Sony\VAIO Media plus\SOHCImp.exe [2008-10-21 103712]
S2 SOHDms;VAIO Media plus Digital Media Server;c:\program files\Sony\VAIO Media plus\SOHDms.exe [2008-10-21 353568]
S2 SOHDs;VAIO Media plus Device Searcher;c:\program files\Sony\VAIO Media plus\SOHDs.exe [2008-10-21 62752]
S2 uCamMonitor;CamMonitor;c:\program files\ArcSoft\Magic-i Visual Effects 2\uCamMonitor.exe [2008-09-18 104960]
S2 VCFw;VAIO Content Folder Watcher;c:\program files\Common Files\Sony Shared\VAIO Content Folder Watcher\VCFw.exe [2009-03-05 5189992]
S2 VcmIAlzMgr;VAIO Content Metadata Intelligent Analyzing Manager;c:\program files\Sony\VCM Intelligent Analyzing Manager\VcmIAlzMgr.exe [2009-09-16 480624]
S2 VMCService;Vodafone Mobile Connect Service;c:\program files\Vodafone\Vodafone Mobile Connect\Bin\VMCService.exe [2008-11-04 14336]
S3 ArcSoftKsUFilter;ArcSoft Magic-I Visual Effect;c:\windows\system32\DRIVERS\ArcSoftKsUFilter.sys [2008-04-24 17920]
S3 btwl2cap;Bluetooth L2CAP Service;c:\windows\system32\DRIVERS\btwl2cap.sys [2008-11-05 29736]
S3 FsUsbExDisk;FsUsbExDisk;c:\windows\system32\FsUsbExDisk.SYS [2009-04-07 36608]
S3 NETw5v32;Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows Vista 32 Bit;c:\windows\system32\DRIVERS\NETw5v32.sys [2010-05-31 6638080]
S3 seehcri;Sony Ericsson seehcri Device Driver;c:\windows\system32\DRIVERS\seehcri.sys [2008-01-09 27632]
S3 SFEP;Sony Firmware Extension Parser;c:\windows\system32\DRIVERS\SFEP.sys [2008-08-22 9344]
S3 TuneUpUtilitiesDrv;TuneUpUtilitiesDrv;c:\program files\TuneUp Utilities 2010\TuneUpUtilitiesDriver32.sys [2010-02-25 10064]
--- Other Services/Drivers In Memory ---
*Deregistered* - PCTSDInjDriver32
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
bthsvcs REG_MULTI_SZ BthServ
LocalServiceAndNoImpersonation REG_MULTI_SZ FontCache
rsmsvcs REG_MULTI_SZ ntmssvc
ipripsvc REG_MULTI_SZ iprip
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Svchost - NetSvcs
UxTuneUp
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{2796e0a1-30be-11de-afe0-806e6f6e6963}]
\shell\AutoRun\command - G:\N8800_SapphireArte.exe
Contents of the 'Scheduled Tasks' folder
2010-09-20 c:\windows\Tasks\AutoSmartDefrag.job
- c:\program files\IObit\IObit SmartDefrag\IObit SmartDefrag.exe [2010-08-12 10:08]
2010-09-08 c:\windows\Tasks\FileCure Default.job
- c:\program files\ParetoLogic\FileCure\FileCure.exe [2010-03-28 19:47]
2010-09-20 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-08-12 00:18]
2010-09-20 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-09-13 c:\windows\Tasks\ParetoLogic Registration3.job
- c:\program files\Common Files\ParetoLogic\UUS3\UUS3.dll [2009-08-04 18:19]
2010-09-11 c:\windows\Tasks\ParetoLogic Update Version3.job
- c:\program files\Common Files\ParetoLogic\UUS3\Pareto_Update3.exe [2009-08-04 18:19]
2010-09-08 c:\windows\Tasks\RegistryBooster.job
- c:\program files\Uniblue\RegistryBooster\rbmonitor.exe [2010-09-08 00:25]
2010-09-12 c:\windows\Tasks\SmartDefrag.job
2010-09-20 c:\windows\Tasks\User_Feed_Synchronization-{103B65BD-4798-4CA0-9487-EB211B637804}.job
- c:\windows\system32\msfeedssync.exe [2010-08-11 04:24]
------- Supplementary Scan -------
uStart Page = hxxp://vaio-online.sony.com/
mStart Page = hxxp://vaio-online.sony.com/
uInternet Settings,ProxyServer = 192.168.1.18:80
uInternet Settings,ProxyOverride = *.local
uSearchAssistant = hxxp://www.google.com/ie
uSearchURL,(Default) = hxxp://www.google.com/search?q=%s
IE: Send image to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
IE: Send page to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
IE: {{B4B52284-A248-4c51-9F7C-F0A0C67FCC9D} - c:\users\Administrator\Desktop\PartyCasino\RunApp.exe
IE: {{d9288080-1baa-4bc4-9cf8-a92d743db949} - c:\users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\IMVU\Run IMVU.lnk
FF - ProfilePath - c:\users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\msq56u7x.default\
FF - prefs.js: browser.search.defaulturl - hxxp://search.yahoo.com/search?fr=ffsp1&p=
FF - prefs.js: browser.search.selectedEngine - Yahoo
FF - prefs.js: browser.startup.homepage - hxxp://www.yahoo.com
FF - prefs.js: keyword.URL - hxxp://search.yahoo.com/search?fr=ffds1&p=
FF - component: c:\users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\msq56u7x.default\extensions\[email protected]\platform\WINNT_x86-msvc\components\WeaveCrypto.dll
FF - component: c:\users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\msq56u7x.default\extensions\[email protected]\platform\WINNT_x86-msvc\components\lpxpcom.dll
FF - plugin: c:\program files\DivX\DivX Plus Web Player\npdivx32.dll
FF - plugin: c:\program files\Google\Picasa3\npPicasa3.dll
FF - plugin: c:\program files\Google\Update\1.2.183.13\npGoogleOneClick8.dll
FF - plugin: c:\program files\Java\jre6\bin\new_plugin\npdeployJava1.dll
FF - plugin: c:\program files\Microsoft\Office Live\npOLW.dll
FF - plugin: c:\program files\Sony\Media Go\npmediago.dll
FF - plugin: c:\program files\Tencent\QQMusic\npQzoneMusic.dll
FF - plugin: c:\program files\Windows Live\Photo Gallery\NPWLPG.dll
FF - plugin: c:\users\Administrator\AppData\Roaming\Mozilla\Firefox\Profiles\msq56u7x.default\extensions\[email protected]\platform\WINNT_x86-msvc\plugins\npfax.dll
FF - plugin: c:\users\Administrator\AppData\Roaming\Mozilla\plugins\np-mswmp.dll
FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
---- FIREFOX POLICIES ----
FF - user.js: network.http.max-persistent-connections-per-server - 4
FF - user.js: nglayout.initialpaint.delay - 600
FF - user.js: content.notify.interval - 600000
FF - user.js: content.max.tokenizing.time - 1800000
FF - user.js: content.switch.threshold - 600000
FF - user.js: browser.blink_allowed - true
FF - user.js: browser.xul.error_pages.enabled - true
FF - user.js: dom.disable_window_open_feature.resizable - true
FF - user.js: dom.disable_window_open_feature.location - false
FF - user.js: browser.tabs.tabMinWidth - 125
FF - user.js: browser.tabs.closeButtons - 1
FF - user.js: yahoo.ytff.general.dontshowhpoffer - truec:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbaam7a8h", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4ar", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled", false);
- - - - ORPHANS REMOVED - - - -
Toolbar-Locked - (no file)
WebBrowser-{D4027C7F-154A-4066-A1AD-4243D8127440} - (no file)
WebBrowser-{081230F8-EA50-42A9-983C-D22ABC2EED3B} - (no file)
HKU-Default-Run-Nokia.PCSync - c:\users\Administrator\Desktop\Nokia PC Suite 6\PcSync2.exe
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, GMER - Rootkit Detector and Remover
Rootkit scan 2010-09-21 05:37
Windows 6.0.6002 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
[HKEY_LOCAL_MACHINE\system\ControlSet001\Services\SampleCollector]
"ImagePath"="\"c:\program files\Sony\VAIO Care\collsvc.exe\" \"/service\" \"/counter=\Processor(_Total)\% Processor Time:5\" \"/counter=\PhysicalDisk(_Total)\Disk Bytes/sec:5\" \"/counter=\Network Interface(*)\Bytes Total/sec:5\" \"/directory=inteldata\""
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Internet Explorer\User Preferences]
@Denied: (2) (Administrator)
"88D7D0879DAB32E14DE5B3A805A34F98AFF34F5977"=hex:01,00,00,00,d0,8c,9d,df,01,15,
d1,11,8c,7a,00,c0,4f,c2,97,eb,01,00,00,00,99,3f,aa,b2,c5,03,2e,44,99,fa,93,\
"2D53CFFC5C1A3DD2E97B7979AC2A92BD59BC839E81"=hex:01,00,00,00,d0,8c,9d,df,01,15,
d1,11,8c,7a,00,c0,4f,c2,97,eb,01,00,00,00,c1,6b,fc,62,db,04,8e,41,bb,4f,64,\
"6256FFB019F8FDFBD36745B06F4540E9AEAF222A25"=hex:01,00,00,00,d0,8c,9d,df,01,15,
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.3fr\UserChoice]
"Progid"="Google.PhotoViewer.3.0"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.@db\UserChoice]
"Progid"="Applications\\SymIMIns.exe"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.aif\UserChoice]
"Progid"="WMP11.AssocFile.AIFF"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.aifc\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.aiff\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.arw\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.asf\UserChoice]
"Progid"="WMP11.AssocFile.ASF"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.asx\UserChoice]
"Progid"="WMP11.AssocFile.ASX"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.au\UserChoice]
"Progid"="WMP11.AssocFile.AU"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.avi\UserChoice]
"Progid"="WMP11.AssocFile.avi"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.BMP\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.cda\UserChoice]
"Progid"="WMP11.AssocFile.CDA"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.cr2\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.crw\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.dat\UserChoice]
"Progid"="Applications\\AcroRd32.exe"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.dcr\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.DIB\UserChoice]
"Progid"="PhotoViewer.FileAssoc.Bitmap"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.dng\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.DVR\UserChoice]
"Progid"="MediaCenter.DVR"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.dvr-ms\UserChoice]
"Progid"="MediaCenter.DVR-MS"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.erf\UserChoice]
"Progid"="WindowsLive.PhotoGallery.raw.14.0"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.GIF\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.htm\UserChoice]
"Progid"="IE.AssocFile.HTM"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.html\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.ICO\UserChoice]
"Progid"="WindowsLive.PhotoGallery.ico.14.0"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.JFIF\UserChoice]
"Progid"="PhotoViewer.FileAssoc.JFIF"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.JPE\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.JPEG\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.JPG\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.kdc\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.loc\UserChoice]
"Progid"="Applications\\ARestore.exe"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.m1v\UserChoice]
"Progid"="WMP11.AssocFile.MPEG"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.M2V\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.m3u\UserChoice]
"Progid"="WMP11.AssocFile.M3U"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mht\UserChoice]
"Progid"="IE.AssocFile.MHT"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mhtml\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mid\UserChoice]
"Progid"="WMP11.AssocFile.MIDI"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.midi\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.MOD\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mp2\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mp2v\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mp3\UserChoice]
"Progid"="WMP11.AssocFile.MP3"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mpa\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mpe\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mpeg\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mpg\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mpv2\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.mrw\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.nef\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.nrw\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.orf\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.pef\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.PNG\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.ptx\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.raf\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.rar\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.raw\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.rmi\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.rw2\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.shtml\UserChoice]
"Progid"="FirefoxHTML"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.snd\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.sr2\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.srf\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.TGA\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.TIF\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.TIFF\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.url\UserChoice]
"Progid"="IE.AssocFile.URL"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wav\UserChoice]
"Progid"="WMP11.AssocFile.WAV"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wax\UserChoice]
"Progid"="WMP11.AssocFile.WAX"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wdp\UserChoice]
"Progid"="PhotoViewer.FileAssoc.Wdp"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wm\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wma\UserChoice]
"Progid"="WMP11.AssocFile.WMA"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wmd\UserChoice]
"Progid"="WMP11.AssocFile.WMD"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wms\UserChoice]
"Progid"="WMP11.AssocFile.WMS"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wmv\UserChoice]
"Progid"="WMP11.AssocFile.WMV"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wmx\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wmz\UserChoice]
"Progid"="WMP11.AssocFile.WMZ"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wpl\UserChoice]
"Progid"="WMP11.AssocFile.WPL"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wvx\UserChoice]
"Progid"="WMP11.AssocFile.WVX"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.x3f\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xht\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xhtm\UserChoice]
"Progid"="Opera.HTML"
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xhtml\UserChoice]
[HKEY_USERS\S-1-5-21-446587383-725776139-2801741393-500\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xls\UserChoice]
"Progid"="Excel.Sheet.8"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil10i_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
@="c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil10i_ActiveX.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
@="{FAB3E735-69C7-453B-A446-B6823C6DF1C9}"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
@="IFlashBroker4"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\software\Microsoft\Internet Explorer\User Preferences]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
@Denied: (A) (Users)
@Denied: (A) (Everyone)
@Allowed: (B 1 2 3 4 5) (S-1-5-20)
"BlindDial"=dword:00000000
"MSCurrentCountry"=dword:000000b5
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0001\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0002\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0003\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0004\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0006\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0007\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0008\AllUserSettings]
"BlindDial"=dword:00000001
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0009\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0010\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0011\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0012\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0013\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0014\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0017\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0018\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0021\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0022\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0023\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0024\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0025\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0027\AllUserSettings]
Completion time: 2010-09-21 05:42:31
ComboFix-quarantined-files.txt 2010-09-20 21:42
Pre-Run: 183,863,402,496 bytes free
Post-Run: 185,407,442,944 bytes free
- - End Of File - - 3E5C59478D2D7F5680A0F0A6B1CC864A
    VGN-CS26G
    Intel(R) Core(TM)2 Duo CPUP8600 @ 2.4GHz 2.40 GHZ
    3.00GB
    320GB
    bluetooth
    I'm sorry some infomations i do not have as i dont know where to get. Kindly let me know wher i can get the info, I'll update. Thanks.
I'd like you to scan your machine with ESET OnlineScan
  1. Hold down Control and click on the following link to open ESET OnlineScan in a new window.
    ESET OnlineScan
  2. Click the
    button.
  3. For alternate browsers only: (Microsoft Internet Explorer users can skip these steps)
    1. Click on
      to download the ESET Smart Installer. Save it to your desktop.
    2. Double click on the
      icon on your desktop.
  4. Check
  5. Click the
    button.
  6. Accept any security warnings from your browser.
  7. Check
  8. Push the Start button.
  9. ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
  10. When the scan completes, push
  11. Push
    , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
  12. Push the
    button.
  13. Push
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
ops, i m sorry. i ran the scan twice & accidentally clicked on remove threats & so the scan says that i've no threats found.
    VGN-CS26G
    3.00GB
    320GB
    bluetooth
Can anyone please help me too... i am facing what i see from these post. The fact is i dunno what happen for my computer to have now became this state... please help me. I only know my computer status is bad & i need serious help. I didnt even know something was wrong till now & if i've read enuff from what i saw frm the post, i guess all i have to say is its very serious. Can anyone please help. Cause i dunno what i can do to help revert anything. All i can remeber is there was a *cmd.exe* pop out pop for the whole day & i ignore & blah blah... next when i realise my com is threaten by virus, its sad... Till now i only tried to do 1 thing which is try download & run a file call "checksur" i think & another 2 more box appear out for me. PLEASE i need some serious help. I beleive the damage is .... Erm, i wish to add, so the correct meaning of understanding this virus, how deep is my damage or isit recoverable? As i usually never let the com sleeps so does that means w/o me it can still access? & all i know is the error shows cmd.exe/drive/harddisk/dr1
Download malwarebytes.org/free verison run quick scan.delete bad files found.
    gateway t3616 desktop
    sata
    generic
    250 gb
    generic
    generic
    generic
    2 drives vista 250 gb Win 7 pro 1tb win 7 frist
    Adding new 1tb drive replacing 160gb drive
We did that in post 2, reply 1. See here: http://www.vistax64.com/system-secu...-anyone-pls-error-0x80092003.html#post1287259
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
