At this point I'm at a loss? Sorry I could not be more helpful. At some point you may have to consider some sort of data recovery software if going back and searching doesn't help? In an almost perfect world, you'll find your files scattered about?
Data recovery takes an awful long time... 8 hours to search, then perhaps another 8 to actually transfer those files to another folder you set up. You don't have to spend $60.00 though. In the Software section they link to a free data recovery app that works well with Vista; although, it's the demo version and can only grab files 64kb or less: http://www.r-studio.com/
However, there are other free tools out there: Top 10 FREE Data Recovery Software » Raymond.CC Blog
I'm not sure whether or not you must remove the drive in order for these tools to work, but I'm guessing so; any software you add to the OS has the potential of overwriting those files you don't want overwritten... once you do that, they're gone... short of really really expensive options.
Do you have a friend who's familiar with machines? Maybe he can take your drive, dl one of these tools and recover the data for you?
***edit***
Just a last stab in the dark... did you check under all the user names in my documents or just yours?
***edit***
- Fumz' Flux-Capacitor
- E8400
- DFI LP DK P35-T2RS
- 4GB G.Skill PC-1066
- eVGA 8800 GTS
- X-Fi XtremeGamer
- Samsung 226BW
- 1680x1050
- 500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
- PSU
- PC Power & Cooling Silencer 610
- Case
- Lian Li Lancool K62
- Cooling
- Thermalright Ultima-90/S-Flex 120mm
- Logitech G5
- MS Natural Elite 4000 Ergonomic
- 2.5MB/430
- Other Info
- D-Link DGL 4500
