Help! BSOD
Wow. Thanks for checking that... I did turn off driver verifier... If it blue screens again you want me to zip the that mini dump file and send it to you? Another question way off subject here... Do you know any good programs that are accurate to tell me what my cpu temp is running? I know how to check in bios but no game play is going on so I don't know if it is getting hot or not during game play as well....... When I check bios it says 17c.
    amd athlon 7850 dual core
    Biostar
    2 GB corsair 240pin 800 DDR2
    Onboard GC
    Onboard SC
    Dell
    1024x768
    240 GB HD
    E-machine case
    Vortex Cooler
    Microsoft
    Gateway 2000
    12 Mb
Id like you to check the link to the Micorosoft Site that says that you need some sort of upgrade for the game. I sent it to you.
Core Temp
After you get the update for the game, and you turn off Verifier if you get more BSODs, post in this thread, do not start a new one.
I wish you luck
Yes I turned off verifier and I guess my cpu temp is really running 15 celcius. I will post in this thread if I do happen to get any more bsods and yes I already have latest patch for game... Thank you very much for your help and I most likely will be contacting you soon. You are a great help sir and I very much appreciate your time and effort.
    Biostar
    Onboard GC
    Onboard SC
    Dell
    1024x768
    240 GB HD
    E-machine case
    Vortex Cooler
    Microsoft
    Gateway 2000
    12 Mb
We are all volunteers and enjoy helping others with computer problems. It is all worthwhile with members like yourself, who show appreciation. Good luck.
hey on the test box it will not allow me to click anything to upload my new mini dump. How would I be able to get it to you?
    Biostar
    Onboard GC
    Onboard SC
    Dell
    1024x768
    240 GB HD
    E-machine case
    Vortex Cooler
    Microsoft
    Gateway 2000
    12 Mb
If it does not work the way it did when you sent the first reports, I have no idea.
Dangit... Could it be because I switched to windows xp?
    Biostar
    Onboard GC
    Onboard SC
    Dell
    1024x768
    240 GB HD
    E-machine case
    Vortex Cooler
    Microsoft
    Gateway 2000
    12 Mb
Sorry again, Vista and Seven are similiar, XP is different. Better find an XP forum to get the best help. I will say, though, if you are having problems with Vista and XP sounds like it hardware (the computer) Sounds like the old memory again. Of course hardware can be many things, Hard Drive etc.
I will write the dump for you in a minute not sure what it is my self download windbg now to decode it...
    Biostar
    Onboard GC
    Onboard SC
    Dell
    1024x768
    240 GB HD
    E-machine case
    Vortex Cooler
    Microsoft
    Gateway 2000
    12 Mb
Never mind the xp pro sp3 didnt come with .net framework 2.0 so I cannot download it ohwell.... Will wait to see if it bluescreens again
    Biostar
    Onboard GC
    Onboard SC
    Dell
    1024x768
    240 GB HD
    E-machine case
    Vortex Cooler
    Microsoft
    Gateway 2000
    12 Mb
