Hdmi to lcd get video no audio
Haven't forgotten about you guys, just sort of out of ideas. Other than that link I posted previously about it not working with certain Nvidia drivers,
HDMI audio doesn't work with new drivers - NVIDIA Forums
double check which driver version you are running, and tif not what is working from that thread, maybe give that one a try.
And trax you definitely need that cable to get the audio over HDMI with Nvidia cards. may or may not help but a bit more info on it here,
Guide: 8800GT/9800GT/9800GTX Sound over HDMI (Now including Creative cards) - Overclock.net - Overclocking.net
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Right I have Grounded and applied live leads to Video card as per instructions.
Am upto date with video and sound cards. I see movement in the sound bar in SPDIF sound properties still no sound.
May there be a problem with the fact I am using a sound PCI card...
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Hdmi no audio
I found out what caused my problem. I had the BIOS AUDIO set to auto and needs to be set to enabled. HP did not know this. TRAX1963 try it you never know.
I tried it but it did not work for me as I have only two settings [Auto] and [Disabled] so no connection as of yet...
But, I still say SPDIF shows activity but no sound!
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
OK one more question are you going from your PC video HDMI to a TV with a HDMI in or a DVI IN.
OK one more question are you going from your PC video HDMI to a TV with a HDMI in or a DVI IN.[/QUOTE]
With a very expensive HDMI lead.
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Haven't read the whole thread so forgive me if this has already been mentioned:
My PC is connected to my monitor via an HDMI cable and my headphones connect to my monitor. I has similar problems with sound being too low and ultimately found out that it was the Volume control on my LCD monitor that was set too low. Raised that to maximum and the sound to my headphones is much better.
See if that will work for you.
OK what is the connection on the TV is it DVI or HDMI.[/QUOTE]
Everything I have is HDMI
TV is Samsung 46" A656
Am thinking of getting ATI card instead of crap nVidia card...
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Solved Solved Solved
My situation has been solved late tonite as I was not able to do it earlier due to the wife wanting to watch TV.
I understand the fact, you need these:~
1. Updated sound card
2. Minimum updated video card to
GeForce ForceWare 190.56 Win 7 | Vista (64-bit) download from Guru3D.com
3. Have cabled up Video card to SPDIF [CORRECTLY]!
The fault I had was I had not connected to the SPDIF correctly!
SOLVED
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
